Results 1 to 11 of 11
Thread: eBay brake rebuild kit?
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    Anyone have any experience with these ebay rebuild kits? They include the pistons which I have not seen from any brand. There is no markings or brand name on their listing.
    http://www.ebay.com/itm/FRONT-Brake-...pTXNSA&vxp=mtr
    I am looking into this because the calipers are not looking too healthy since the car sat for years before I got it. Just preventative.
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Never heard of this company, but they claim: Bigg Red – Brake Caliper Reman & Coating Specialist, the leading UK Brake Caliper Remanufacturing and Component Specialist, with over 100,000 caliper components in stock. http://www.biggred.co.uk/
    looks good, price is fine, maybe you give it a try.
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    I think the price is okay. You can get the rubber bits for cheap. As for the pistons, you can get them for about $22 each. So I would say a fair price for convenience versus buying pistons and kits separate. The problem I ran into is corrosion on the side of the caliper too. I had a thread a while back with pics of the crap I found inside, it was bad. But I polished everything up and used a Dremel inside the calipers to clean them. With new rubber bits, no issues every since I rebuilt em.
    ______________________________
    1992 750iL
    Oct 2007
    Boca Raton, Florida
    I may give this a try. My mechanic seemed to have fix that bleeding issue while the car was in for suspension work, he kind of just said "oh I fixed your brakes btw" lol, no charge. He did mention that the right front was braking harder than the rest and you could see it too. Afraid of rusted or pitted pistons so I will look into these when I get the car back. I saw Johan and Seans page on this but they had a lathe to put the pistons in and polish with sand paper. I dont have that.
    Thank you both.
    Mar 2016
    Lincoln, NE
    91 735iL
    Have you thought of just getting remanufactured calipers? My bleeder screws broke off on both my front calipers and I got remanned units from Rockauto for less than 100 bucks.
    Oct 2007
    Boca Raton, Florida
    Quote Originally Posted by NE32 View Post
    I did want to do this but any of the REMAN ones I found where an off brand caliper, no the original ATE. Im sure it doesnt matter but if that was the case I would have rather replaced piston and seals on my ATE ones and keep them.
    Mar 2013
    Green Bay, WI
    Are you sure? Usually the rebuilds are sold as one of two brands. ATE or Bendix. Best to match to what you have.
    For example, this is an ATE actually.
    1992 750iL
    Oct 2007
    Boca Raton, Florida
    Maybe the ad is confusing me. I dont see any images of the actual brand on the caliper though so ive strayed away. i will keep looking though. Is that from RockAuto?
    Mar 2013
    Green Bay, WI
    yes, Rockauto. If you bring up that example above, the caliper says ATE.
    1992 750iL
    Jan 2005
    Japan
    I have asked the chaps on the U.K. forum with regards to that company in U.K., reply: Erich, I used one of their kits on my offside front caliper about 18 months ago. it has been fine since. I replaced the nearside prior to that by buying an exchange caliper through our local motor factors. The rebuild kit was was about a third the price of the exchange kit. Only difficulty i experienced was fitting the new dust seal in, that was awkward. I would be happy to use them again.
    Mar 2016
    Lincoln, NE
    91 735iL
    Quote Originally Posted by SergeBMW View Post
    The ones I got where ATE if I remember correctly. I'll check when I get home. Been on the 7 since march and no problems.
  1. E36 325i Parking Brake Rebuild Kit
    By Reizvoll in forum Brake Kits, Rotors & Pads
    Last Post: 02-12-2013, 06:16 PM
  2. Ebay injector rebuild kit, is it good ?
    By fahdyehia628 in forum 1991 - 1999 (E36)
    Last Post: 03-18-2012, 01:06 AM
  3. eBay suspension rebuild kit?
    By golde30 in forum 1988 - 1996 (E34)
    Last Post: 04-01-2011, 09:21 PM
  4. where to buy Brembo brake rebuild kit?
    By forksports in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2008, 12:40 PM
  5. Brake Rebuild Kit
    By TBM311 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-16-2007, 09:37 AM
