Hello All,
I bought the software from an EBAY guy and I believe I've installed the software properly.
I've got the DIS software up and running. It can see the DIAGHEAD software properly and I've got ifhsrv32 working.
I believe my issue is with my connector. I'm using a blue OBD cable that I've used before with DIS in the past with another copy of software (FTDI Drivers appear to work), but I've lost that software a while ago.
Does anyone have any suggestions on what I can check on?
Thanks,
-Sean
If the software needs to run using a diaghead emulator, it is not set up correctly and will run as slow as a wet week. Run an APItest to ensure you have communication with your interface. https://www.bimmerforums.com/forum/s...6#post27153566
