Results 1 to 8 of 8
Thread: How to tighten front strut top nut?
    Sep 2017
    Colorado
    1997 e36 M3 Sedan
    If you have done this, you know exactly what my issue is. The top nut is sunken in to the top mount, so you can't get an open end wrench around it, and you have to use a hex too in there to keep the shaft from spinning.
    I was able to tighten the bolt by using some big needle nose pliers to hold the nut while I used a socket to turn the hex. Not sure if I will be able to torque it down like that though.
    There must be a better way to do this.
    Thanks!
    Dec 2013
    Chicagoland area
    EXOTICS
    Sep 2017
    Colorado
    1997 e36 M3 Sedan
    Hell yeah, thanks man!
    Jun 2010
    NY
    1997 328i
    You make your own tool. You take a socket for the large nut and grind two flats so you can use an adjustable wrench on the flats. Smaller driver will fit inside the larger.
    Wrong way to do this is to use vise grips to hold the piston.
    Aug 2009
    sunnyvale CA
    325is
    Oct 2003
    Seattle
    99 M3
    Three different options!!
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by 303e36 View Post
    Thanks!
    Most guys just use an impact and hold the shaft by hand through the springs. You won't spin the shaft if you're even just a little careful. The hex hole usually strips out, so holding it is often the only option.
    Wisconsin
    98 328IS 03 325xi
    For $30 you can get one of these sets and use the 7/8" socket. https://www.menards.com/main/tools-h...9430009&ipos=1
    Gave away my BMWs, driving a VW and an Audi now.
  1. Bilstein HD front strut top nut torque specs?
    By alpinewhite318i in forum 1983 - 1991 (E30)
    Last Post: 09-04-2017, 10:54 AM
  2. Tightening front strut top nut?
    By Jpclarke89 in forum 1991 - 1999 (E36)
    Last Post: 02-24-2014, 01:50 AM
  3. Tightening Front Strut Top Bolt
    By megamax in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-26-2012, 08:50 AM
  4. How to remove front strut collar nut
    By Actros617 in forum 1988 - 1994 (E32)
    Last Post: 06-04-2010, 03:41 PM
  5. How to: Shortening front Struts?
    By etxxz in forum 1992 - 1999 M3 (E36)
    Last Post: 10-23-2008, 11:14 AM
