Results 1 to 8 of 8
Thread: 01 M roadster running hot
    Mar 2002
    chicagoland
    NUTIN
    Hi all,
    I had my M for almost 2 years. I don't drive the car much but everytime I drive the car notice that temp gauge gets well past half way mark when it's not even hot out. Checked coolant level it looks good. Car is completely stock. Anything I should do?
    96 2DR SILVER M3 ***SOLD***
    MODS:
    JC INTAKE
    SOFTWARE
    UUC SSK
    01 M Roadster - Stock
    87 Buick Turbo T
    A LITTLE OF THIS........TRY ME!
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    Have you had any reason to add coolant recently (and maybe had an air lock in the system)?
    T-stat working ? If it is stuck closed, the coolant won't circulate through the radiator.
    Waterpump? Similar problem if the impeller is not pumping coolant through the system.
    Greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
    Mar 2002
    chicagoland
    NUTIN
    Never had to add coolant. I assume thermostat is working because I have heat. How do I check water pump? It's not leaking.
    MODS:
    JC INTAKE
    SOFTWARE
    UUC SSK
    87 Buick Turbo T
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by 2gns4me View Post
    everytime I drive the car notice that temp gauge gets well past half way mark when it's not even hot out...Anything I should do?
    ?!? Don't drive the car again until you've gotten to the bottom of the gauge reading hot for one thing.
    Don't make any assumptions in diagnostics.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The dash gauge is both heavily dampened and inaccurate. Normal is a few degrees left of center, and it takes another 20C to make it move farther. Quit guessing and put a real gauge on it. An OBD2 scanner will be fine.
    Kent, Ohio
    1998 M Roadster
    OP, when you say the temp gauge, you are referring to the coolant temp gauge in the instrument cluster, not the oil temp gauge in the console, right?
    May 2017
    NW Indiana
    My understanding (and maybe I am wrong) is that the T-Stat is going to open to flow coolant to the radiator once the temp gets up to operating temp. Until then, you are going to have warm coolant flowing in the block and thof heater.
    If the T-stat is stuck closed, you never get coolant flow through the radiator...and she will overheat.
    I dont think "heat" means your thermostat is working.
    How about checking the temp of the radiator hoses once the car is warmed up, or check the radiator itself (non-contact thermometer shoud work. If they are not hot, I would assume that the T-stat is not opening, and could be a source of your overheating.
    Just my guess.
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Jun 2003
    Las Vegas
    M Coupe
    Quote Originally Posted by rf900rkw View Post
    This... Hit it with an infrared gun
    99 M Coupe
    99 996 Cabrio
    86 Saleen Griggs Road Race Car
  1. 1998 M Roadster Running Hot
    By MSpeed98 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-30-2012, 11:01 PM
  2. M Roadster running hot ...
    By viper501 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-30-2003, 11:36 AM
  3. Christmas Run, me (01' M-Roadster) and honda CBR 1000
    By DINANISR3 in forum Kill Stories
    Last Post: 12-28-2002, 07:36 PM
  4. Performance upgrade for 01+ M Roadster/Coupe
    By bimmerpwr in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-18-2002, 12:05 AM
  5. Got 01 M Roadster (315hp version) instead of super charging it
    Last Post: 04-02-2002, 11:29 PM
