Results 1 to 22 of 22
Thread: M bumper lip prototype
    Jul 2012
    canada
    2002 M Roadster Imola
    What do you thing? FDSC03486.jpgiberglass fabrication.DSC03482.jpgDSC03476.jpgDSC03475.jpg
    Oct 2003
    Seattle
    99 M3
    Looks good. Are you developing this product yourself?
    Kent, Ohio
    1998 M Roadster
    Looks great, but the M bumper is already pretty darned low to the road now, I wouldn't want to loose another couple of inches--I'd be bottoming out all the time.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Not really. The only reason an M bumper is lower is because of the slightly lower ride height. The actual height dimensions of the bumper are identical to the 6cyl.
    /.randy
    Aug 2014
    kentucky
    '98 Z3 M Roadster
    Yeah I'm afraid it might only look nice a month before I lost it to bottoming out. Nice work tho...
    Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
    Dec 2007
    Great Dismal Swamp
    The new air opening created.... where does it go? Is it plumbed back up into the radiator, or just dump under the car?
    /.randy
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    Make it out of something more durable and I'll take one.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
    Can you share the process of making it? I'm trying to get some fiberglass parts I made reproduced but nobody has been able to help me
    PRICE CUT on ALL FABRICS
    Jul 2012
    canada
    Yes i developing this lip. Air go under the car. If i can build with Gyftane (better then fiberglass), i will build a few for sale. It's right, front bumper is low with this lip, but my roadster is with low coil-spring (not original coil-spring).
    No hold to drill, no modification, 5 minutes for installation.
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    I think that looks cool as hell.
    How much lower does it make the front bumper?
    Greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
    Jul 2012
    canada
    BimmerBreaker: for now the molding is just made with wood material.
    Tallyho322: height from the road 3.5p, lip height 1 5/8p, car height from fenders to the ground: front 25p rear 26.5p
    Sep 2017
    Northeast
    2001 M Roadster
    I will take one, if reasonably priced.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    I think aesthetically it should be wider at the sides. And splitter parts near the centre should start where the actual splitter starts (or continue that diagonal line).
    @bimmerbreaker, fiberglass parts creating is basically the same as any other composite part creating. Check this page for good tutorials: http://www.easycomposites.co.uk/#!/composites-tutorials
    Aug 2008
    Sunny SoCal
    E368x2 / F15
    Great work, nice to see people still busting out ideas for the 368 chassis.
    I have a couple prototype aero parts for the M Coupe collecting dust. Never found someone to cost effectively reproduce them.
    Jul 2012
    canada
    [QUOTE=deni2s;29857519]I think aesthetically it should be wider at the sides. And splitter parts near the centre should start where the actual splitter starts (or continue that diagonal line).
    Thanks for comment: Wider is not possible oem bumper is ronded, lip will be higher from the ground at the end each side.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by teachermechanic View Post
    Check the Hamann lip, they made it wider.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Wadsworth, Ohio
    BMW
    I dig it, makes an already aggressive front end ever more aggressive!
    -James
    Mar 2003
    somers,ny
    it makes an ugly M frt bumper look better
    Jul 2012
    canada
    Quote Originally Posted by jrkoupe View Post
    Thanks for comment
    Attachment not work for me.
    Jul 2012
    canada
    Deni2s: are you refered to this model?
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    This looks like the Hamann non-M splitter, with a filler center section for the M's bumper. I've always like the look of the non-M bumper personally, and I think the Hamann splitter makes it even better...I should've never sold mine.
    It looks great, but wouldn't last more than a few weeks on any lowered car...unless you can make it out of ABS or some type of poly/plastic material. The problem with fiberglass and carbon fiber bits is that they don't like making contact with asphalt/concrete.
    @BimmerBreaker: Are you referring to the parts you messaged me about? If so, I'm waiting for pics in order to get you a quote. I can do either fiberglass or CF. Reproducing stuff is rarely the problem (we haven't had any car parts that we weren't able to reproduce yet)...it's usually the costs that prevent it from happening. If you're still interested, just let me know...and send some pics of the items in question.
    @Msilvia: Hey brother, I'm gonna text you about what you've got. I'm in the process of doing some full CF mirrors, and would love to hear what it is you're looking to get reproduced.
    "You don't win silver....you lose gold."
  1. Installed Zender front lip spoiler today!! Pics -
    By DDD in forum 1991 - 1999 (E36)
    Last Post: 05-11-2013, 07:37 PM
  2. Front bumber Lip
    By BunzM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-01-2008, 03:34 PM
  3. front lip spoilers for m3 bumper
    By 94_325is in forum 1992 - 1999 M3 (E36)
    Last Post: 03-30-2001, 04:38 PM
  4. RD Front LIp Spoiler for sale (ebay)
    By rgol in forum BMW Parts For Sale
    Last Post: 03-02-2001, 09:29 AM
  5. this is the sweetest DTM lip spoiler I heve seen
    By blubimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2001, 07:00 PM
