For those that were successful using it in the past, it seems Internet Explorer still supports JAVA. I thought Edge was just an updated version of IE. I found I have both on my laptop so I opened IE, downloaded JAVA and to my surprise, bmw-planet is working. Still need the exception on the JAVA console in the Control Panel.
Edit: In addition to bmw-planet, the WDS link below covers later models. The index page is Russian but the diagrams are all English. You need to add https://bmw.etk.club to the exception list and up the JAVA console Security to Very High.
https://bmw.etk.club/wds/index.htm
I still have Firefox 52 on my desktop so it's still working there as well. Not sure how long Mozilla will let me go without updating.
Test.
Passenger's door module
Connector overview
Pin assignments at connector A X889
Number X-number of pins Description X889 5 Passenger's door module Connector A X1130 12 Passenger's door module Connector B X1131 18 Passenger's door module Connector C
Pin assignments at connector B X1130
Pin Type Description / Signal type Connection /
Measuring notes1 E Terminal 30 Fuse F8 2 M Control module ground Ground splice 3 Not used 4 A Power window motor signal: close Passenger's window motor 5 A Power window motor signal: open Passenger's window motor
Pin assignments at connector C X1131
Measuring notes1 A Outside mirror drive signal Passenger's side mirror 2 A Outside mirror drive signal Passenger's side mirror 3 A Mirror adjustment signal Passenger's side mirror 4 A Vertical mirror adjustment signal Passenger's side mirror 5 A Mirror heating Passenger's side mirror 6 A Horizontal mirror adjustment signal Passenger's side mirror 7 A Mirror heater potentiometer ground Passenger's side mirror 8 A Microswitch ground supply Passenger's side mirror 9 E Mirror hinged in signal Passenger's side mirror 10 E Mirror potentiometer, horizontal Passenger's side mirror 11 E Mirror potentiometer, vertical Passenger's side mirror 12 A Mirror potentiometer, positive Passenger's side mirror
Measuring notes1 A Unlock motor signal Passenger's door lock motor 2 E up to 08/1995 Not used as of 09/1995 Position 1 memory signal Passenger memory switch 3 E Open window/auto. close signal Passenger's power window switch 4 Not used 5 E up to 08/1995 Not used as of 09/1995 Position 2 memory signal Passenger memory switch 6 E Passenger's door contact signal Passenger's door jamb switch 7 E up to 08/1995 Not used as of 09/1995 Central locking signal Electrochromic rear view mirror 8 Not used 9 A up to 08/1995 Not used as of 09/1995 Central locking signal up to 09/1996 Electronic drive-away protection control unit (EWS)as of 09/1996 Electrochromic rear view mirror 10 A Lock motor signal Passenger's door lock motor 11 E/A P-bus signal line P-bus splice 12 E Close window/auto. open signal Passenger's power window switch 13 E up to 08/1995 Not used as of 09/1995 Position 3 memory signal Passenger memory switch 14 Not used 15 E up to 08/1995 Window monitoring as of 09/1995 Not used Passenger's window monitoring switch (DWA) 16 E Motor position signal Passenger's door lock motor 17 E Pressure-sensitive finger guard system signal Passenger's side pressure-sensitive finger guard 18 E up to 08/1955 Not used as of 09/1995 Memory LED signal Passenger memory switch
Didn't know IE was still good for WDS, I also have an older version of Firefox that is working. I have updates disabled so we should be good lol.
Also if you download or have a online installer make sure you very quickly disable auto updates otherwise it will patch it before you can do anything...i'm sure you already knew that but I'd figure i'd relay it here.
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
Good tip, thanks. I think I have Firefox set to ask before update so i get a half dozen pop up to do so each day.
This is why I don't allow my Firefox to auto update. It breaks some addons, and it certainly breaks some important things such as the WDS.
I have the last WDS disc data, saving them for when that's the only way to do it. In a virtual machine WindowsXP.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
you got a copy of that disk? i have a diag laptop but don't have a offline WDS
I did the same thing. I purchased it off Ebay for $10-15 I think. Have not tried to download it yet.
