Results 1 to 22 of 22
Thread: For the lack of a $5 plastic plug"
    May 2017
    NW Indiana
    2000 BMW Z3 M Roadster
    My 2000 Z3 M Roadster is leaking antifreeze and I started looking around the cooling system for the culprit... found the radiator drain plug leaking.
    Put a socket on it, and it was loose...and the head came right off.
    Spent the the day at my local BMW dealer, and every auto parts store in the area, but no one had a replacement.
    Spent an hour on-line looking, and it seems that the specific plug fits a whole bunch of BMW models...hard to believe not one auto parts store carried the plug.
    I was was able to back out the broken piece of the plug out, with just a flat blade screw driver. Recovered the o-ring too.
    But it now have to order a $5 plug and pay $15 to ship it. What a pain.
    Anyone have a similR issue and come up with a "local" solution?
    Greg
    Tally Ho
    http://wcwebs.net/johnson
    1988 O'Day 322 sailboat - (unlimited mpg)
    2000 BMW Z3 M Roadster (25 mpg - but who cares)
    2019 Subaru Outback
    (30+ MPG)
    Oct 2003
    Seattle
    99 M3
    Clean thoroughly and superglue the head back on. Then only tighten enough to seat the o-ring
    Replace ASAP
    Quote Originally Posted by bluptgm3 View Post
    Would't trust that on a radiator drain plug...
    I would have just hopped over to a junkyard or something to grab one off a car there. Aftermarket brass screws are also available
    PRICE CUT on ALL FABRICS
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Get the correct part, then install it to the correct torque, roughly 0.01 ft-lb. Probably ought to order a new bleeder screw, alo. Whoever made sure that drainplug was "good-n-tight" likely did the same to the bleeder.
    /.randy
    May 2017
    NW Indiana
    Thanks all.
    I dont think I would trust one that was glued together...
    Will order replacement from Pelican or Autohauz I guess. Maybe better order 2��
    And the brass purge screw while a am at it...but I have had it out already and it seems ok.
    But since both both of these can dump the coolant, better be safe.
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Dec 2007
    Great Dismal Swamp
    The plastic plugs, bleeder and drain, are absolutely fine... until some gorilla tightens them as if they were steel. The brass plug is so said gorilla can rip the threads out of the plastic expansion tank. The sealing of the plugs is radial via the o-ring; it requires zero torque to seal properly.
    /.randy
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    A steel bolt has the same metric thread, accepts the o-ring and only requires hand tightening.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
    May 2017
    NW Indiana
    Quote Originally Posted by E.Hands View Post
    Thanks. Maybe I can try this tomorrow and see if she holds.
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Oct 2003
    Seattle
    99 M3
    Go stainless
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    I bought a brass drain plug when I replaced the radiator, but am staying with the plastic plug after reading here that it's a safety feature. Overtighten the plastic and break the plug. Overtighten the brass and ruin the radiator.
    BMW MOA 696, BMW CCA 1405
    Jun 2004
    2001 M Coupe
    Remember: plastic threads and finger tight will be alright. Frequent periodic checks have proven this to me for many years.
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    Dec 2014
    Near Seattle WA, USA
    1999 Z3 Coupe
    Wrecking yard. Until the new one shows up. Then throw the spare in the glove box.
    May 2017
    NW Indiana
    Quote Originally Posted by steveo539 View Post
    I don't want to have to drain the new antifreeze out and reuse it....so I decided to wait until the part comes later this week. Had a M10 bolt in my hand today at the hardware store, but decided I could wait a few days for the right part to get here.
    Weather in the Chicagoarea sucks this weekend anyway, so not driving the Roadster.
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Oct 2003
    Seattle
    99 M3
    For a couple of days it would be just fine. I’m not suggesting a long term solution.
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Am I the only one here who has managed to undertighten these?
    I'm gonna remember that
    Quote Originally Posted by LannVouivre View Post
    I have on multiple occasions started filling systems with no drain plugs at all... undertighten though? Don't think so. Maybe the threads are stripped on yours?
    Wadsworth, Ohio
    BMW
    Words to live by right here.
    And for anyone else that finds this thread and goes "I need that" it's part number 17111719384, I even have a note on our site for the part that basically says "you're going to strip the old one", guess I should add or snap the head off.
    May 2017
    NW Indiana
    Does the cooling system really hold 11 quarts of coolant? That seems like a lot, and I did not get that much in my catch pan when I pulled the plastic drain plug out of the radiator.
    That is like 3 gallons...right?
    Greg
    Tally Ho
    2019 Subaru Outback
    (30+ MPG)
    Oct 2003
    Seattle
    99 M3
    That’s including the volume remaining in the block. The drain plug is between the head pipes in the side of the block.
    Jun 2016
    Odessa, TX
    Quote Originally Posted by BimmerBreaker View Post
    Nope, just was too concerned about stripping them. Whenever I see a phillips head fastener, I have flashbacks of all the screws I've stripped out.
    Dec 2007
    Great Dismal Swamp
    Ummmm, not a phillips. It's a straight slot. Two actually.
    /.randy
    Jun 2016
    Odessa, TX
    That doesn't make it any better!
  1. where do you get plugs for the back of headlights?
    By Bengali86 in forum BMW Rides & Events
    Last Post: 12-19-2005, 06:06 PM
  2. Replies: 0
    Last Post: 01-20-2003, 10:25 AM
  3. The One Lap of America....Not for the faint of heart
    By Bimmerhead in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-21-2002, 04:26 PM
  4. just for the sake of argument :(
    By Guillermo in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-27-2001, 02:57 AM
  5. Replies: 3
    Last Post: 07-05-2001, 11:40 PM
