does is slide down or lengthwise? seems "stuck" and don't want to break it.
TIA
You actually have to pull straight up. It is typically really stuck in there good. It should come up with the clips attached. While the clips themselves slide into key slots in the trim piece, there is not room to slide the trim forward or backwards to separate it from the clips when installed. The clips slide in horizontally to the trim piece, but like I said, you don't slide it to remove, you pull firmly straight up.
thanks BillConn but up isn't an option. its on the bottom edge of the door on the outside.
http://www.realoem.com/bmw/enUS/show...diagId=51_2132
Down, start at an edge.
Mine slid back towards the rear of each door. I think others are talking about a different piece. Maybe yours had a bit of rust on it preventing it from moving? Mine needed a firm tug to get started and then slid right off.
Sent from my XT1572 using Tapatalk
They Slide off. Super easy
Sent from my SM-N950U using Tapatalk
2000 740i Sport
They also fall off quite easily with age, so a previous owner may have glued them on - like mine did, albeit very poorly.
|| 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
Hmm: "up", "down", "side". Sounds like free advice.
how is it supposed to attach to the door bottom? my RR trim piece is not loose, but it is incorrectly angled up.
Which is the correct part number for it? several options available...
WTB the following Highline/Individual parts for my 2001 750iL in Black (updated Apr 2016):
-front sport seat-back cushion
-rear U.S. entertainment armrest with radio/MID/seat/phone/shade/etc controls
-rear digital climate control with rear blower and black leather housing/console
-glovebox and rear right 2001 LHD 750iL wood trim with flag inlay; maybe the dash pieces too
~Ryan
I`ll have to make a video for some of u guys that cant grasp the "Slide off technique"
#2 on Real oem( door side moldings are not slid off but all you do , with your fingers, is get underneath the far right or far left of the molding and pry with your finger tips, between the door panel and molding and LIFT or PRY upwards...Easy too
2000 740i Sport
