Results 1 to 2 of 2
Thread: FS: e46 330i Race Car
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    BMW e46 330i sedan, 8legs Racing #77
    Campaigned in the Canadian Touring Car Championship (CTCC) by a variety of drivers, has earned many podiums and race wins. Car is well sorted, completely turn-key, and ready to race.
    Sample Lap times: Mosport 1:28.0, Calabogie 2.14.5, Tremblant 1:45.1
    SOLD
    Chassis and Aero
    - built in 2010 from a completely rust-free un-crashed donor
    - 10 point cage tied into front strut towers and rear subframe mounts
    - Stripped and gutted interior, doors, trunk
    - Rear and side Lexan windows, OEM windshield
    - Carbon fiber hood
    - M3 style front bumper
    - Custom molded full undertray and splitter
    - APR GT-250 70” wing with 10” cord
    - 2750 lbs post-race weight
    Safety and Interior
    - Racetech RT4009HRWT head restraint seat
    - Schroth 6 point Profi-II belts
    - Sparco 330mm steering wheel with quick disconnect
    - Side window net
    - SPA firefighter 6 nozzle fire system with 2 pulls (driver and external)
    - Motorola CM200 multichannel wired radio, PTT, IMSA harness plug (NASCAR style adapter included)
    - AiM MXL Pista dash and logger with GPS, canbus to ECU
    Suspension and brakes
    - Moton triple adjustable remote reservoir race dampers, regularly rebuilt
    - Various spring rate setups available (setup notes for each track included)
    - Spherical bearings and solid bushings at all joints and mounts
    - GC roll center correcting kit
    - GC bump steer correcting kit
    - GC infinitely adjustable front anti-roll bar
    - Custom top mounted camber plates (cut and welded strut tower tops)
    - Wilwood SL6R calipers and 330x32mm discs, brake ducts, OEM 330i rear
    - Tilton floor mounted pedal box (clutch, brake, throttle) with remote MCs
    Drivetrain
    - ZF 6-speed transmission
    - Tilton custom 5.5” dual disc clutch and 1 piece flywheel (12 lbs total)
    - CAE shifter with reverse lockout, adjustable gate stops and returns springs
    - Diffsonline 4.44 race diff, full race carrier, adjustable pre-load
    - OEM driveshaft
    - OEM axles, rebuilt with Redline CV2
    - Apex ARC-8 17x9 wheels (4) dry
    - Kosei K1 17x8.5 wheels (4) wet
    Engine and Under the hood
    - 3.2L S52 iron block, 11.5:1 CR, Sunbelt cams, ARP studs
    - Custom intake elbow and 70mm Accufab TB
    - 285 rwhp/ 245 rwtq
    - VAC oil block and remote Canton oil filter
    - Fluidyne dual pass oil cooler
    - FSR custom dual pass radiator and SPAL fan
    - Accusump and baffled oil pan
    - AN plumbing throughout
    - Electric water pump
    - Electric PS pump
    - Link G4 Xtreme ECU, tune for 98 Sunoco 260GTX
    - Custom wiring harness and switch panel (wiring diagrams included)
    - Raceland headers (euro SuperSprint copy), 3” exhaust with magnaflow muffler
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Car is sold.
  1. FS: 2001 E46 M3 Race Car
    By dhuberty in forum Race Cars & Track Parts
    Last Post: 03-03-2014, 07:29 AM
  2. E46 2004 e46 m3 race car
    By eleanor665 in forum Race Cars & Track Parts
    Last Post: 11-13-2012, 04:43 PM
  3. Fs: 2004 e46 m3 race car
    By eleanor665 in forum 3 series & Z Series
    Last Post: 11-05-2012, 11:04 AM
  4. FS: E46 M3 Race car, C-Mod/GTS-4
    By maxxfish in forum Race Cars & Track Parts
    Last Post: 05-29-2012, 08:49 PM
  5. E46 2002 BMW E46 M3 Race Car
    By abperry1 in forum Race Cars & Track Parts
    Last Post: 12-13-2011, 09:40 PM
