Results 1 to 6 of 6
Thread: Check control message
    Mar 2014
    san antonio texas
    1989 bmw 750il
    I get an intermittant "check control" message sometimes when I start the car. Then "see owners manual". Owners manual say take it to dealer. Supposedly too many issues to display? Im thinking road trip to junkyard. Are these CCM's interchangeable?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Is that a Japanese version E32? Or it may have a jap. CCM? Because in Japan spec. E32 that procedure is standard when you switch ignition on. Just a test procedure if these warnings work.
    In case there are too many issues to display, that looks different, see here page 24, then there is a plus sign http://750il.bmw7.hu/owners_manual/framed.html
    All CCM are interchangeable. But you can also resolder it, see here the German instructions http://www.e34-welt.de/tips_tricks/R...0e34%20e32.pdf
    on page 8 is the important picture, the red marked parts have to be resoldered
    Mar 2014
    san antonio texas
    1989 bmw 750il
    Its a USA version. I'll dig around and update.
    Mar 2014
    san antonio texas
    1989 bmw 750il
    Thanks for the links Shogun. I opened up the old one and examined it with a magnifying glass. Nothing real obvious stood out. It seems that during one of my many junkyard runs I picked up a CCM and forgot about it. I plugged it in and so far so good.
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    I get the same message on every shutdown now. Annoying. Its not from too many messages as I have other messages after for low washer and brake pads (forgot to install new sensor).
    ______________________________
    1992 750iL
    Brantford ON Canada
    735iL - 1989
    Quote Originally Posted by tsmcg161 View Post
    If you remove the CCM from your car, then you will always see the "Check Control" message. It means that the signals were not received as expected. The fix is to re-solder every pad in the CCM, which is tedious.
    Spend this Quality time with your CCM! Use a 40 watt iron, outdoors.
  1. LOW BEAM check control message.
    By Bradams540 in forum 1988 - 1996 (E34)
    Last Post: 03-09-2008, 01:46 PM
  2. Check control message is getting annoying
    By Fleksta in forum 1988 - 1996 (E34)
    Last Post: 03-04-2007, 11:29 AM
  3. Check Control message
    By Gunslinger in forum 1988 - 1996 (E34)
    Last Post: 02-08-2005, 03:26 PM
  4. Check Control Message
    By IR330 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 02-15-2004, 04:12 PM
  5. partialy legibal OBC check control message: please help
    By JaredG in forum 1992 - 1999 M3 (E36)
    Last Post: 02-10-2004, 10:57 AM
