Results 1 to 4 of 4
Thread: Hard starting after sitting for short while
    Richmond, Virginia
    '88 735i, '06 RSX
    On to the next problem it seems, as is common with E32s...
    I left my E32 735 undriven this week, came to use it tonight to go to Friday night dinner....was very hard to start. Cranked for about 10 seconds before it started, then quit. Cranked again for 10 seconds, started up very weak with my foot on the throttle all the way down, then eventually came up to speed and idled rough. eventually it smoothed out a little bit, but acceleration was still sluggish and the car acted like it was missing sometimes under heavy load. Within the past 10K miles, it has had new plugs, new battery, new alternator, and new fuel filter, had top tier gas this whole year while under my ownership. You guys think its fuel pump, fuel injector, or maybe even AFM related?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    2 possibilities: a sign for a defective fuel pump check valve, all the fuel under pressure in the lines from fuel pump to fuel pressure regulators drains back to the tank. But I thought you installed a new check valve some months ago? https://www.bimmerforums.com/forum/s...k-valve-repair
    Another possibility is that the fuel injectors are leaking and flooding the cylinder, then ignition is also not that easy.
    Air leaks? When you have started the engine, spray some break cleaner around the intakes, but careful, that stuff burns quickly.
    Smoke test is of course the best.
    Richmond, Virginia
    '88 735i, '06 RSX
    Quote Originally Posted by shogun View Post
    Yes, I forgot to mention I did the fuel check valve not so long ago.
    Perhaps it is the injectors, I have not changed them. Would running some cleaner maybe help fix the leaky injectors? I would have figured the detergents in top tier gas would have prevented something like this..
    i forgot to also mention, slight smell of fuel after driving for a short bit and turning off the car.
    personally I don't like to play with flammable fluids near a running engine, but I also don't have a smoke machine...hmm. Does anybody have a vacuum hose diagram for all locations on the m30b35?
    Jan 2005
    Japan
    2nd from bottom, vacuum hose diagram http://www.nmia.com/~dgnrg/page_2.htm
    CroughtonE32 has a good pic of the connection on the underside of the intake.
    Fuel line pressure/leak you could test, see workshop manual, also here some info https://www.injectorrx.com/leaking-fuel-injectors/
    also make a stomp test https://www.bimmerforums.com/forum/s...e-pedal-faults
  1. Hard to start after sitting for a few hours
    By deanda1229 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-05-2013, 10:31 PM
  2. 325is hard start after sitting for 1-2h
    By answ3r in forum 1991 - 1999 (E36)
    Last Post: 12-14-2012, 04:06 PM
  3. Car won't start after sitting for a year
    By Outside Groove in forum 1983 - 1991 (E30)
    Last Post: 11-04-2009, 07:09 AM
  4. after sitting for a while and start up it smells like gas
    By skylinergtr in forum 1988 - 1996 (E34)
    Last Post: 08-23-2009, 05:55 PM
  5. New to me 1995 525iT won't start after sitting for 3 wks
    By andrewcconti in forum 1988 - 1996 (E34)
    Last Post: 12-20-2007, 06:41 PM
