Results 1 to 3 of 3
    May 2005
    Iowa
    1991 325ic, 1994 325is
    e53 x5 4.4 vs 4.8is for winter use
    I'm debating between a 4.8is and a 4.4. My daily is an e46m3 vert. My winter driver is currently a suburban and I'm dreading the downgrade in driving fun. I was debating between the 4.4 and 4.8is. I used to own a 4.4 but have not driven a 4.8is. Is there that much of a difference in acceleration that you can "feel" it? How is the winter driving with the 4.8is? I've read that the standard wheel setup doesn't work in winter and needs to be swapped out?
    Cheers!
    2002 M3 Vert 6 speed with hardtop
    1991 325i 'vert auto
    1994 325is 5spd
    2004 x5 4.4
    2001 325i sedan
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Both models hav the same AWD system...but winter driving requirements depends on what type of conditions you'll be driving in.
    If you live in snow country where winter driving can have consist of deep snow, ice, freeing rain, consistent temps below 45° F....then what make the difference is tires that can handle the driving conditions. If you have summer or all season tires mounted and you'll be driving in wet/snowy/icy/dry/cold conditions and ambient temps are below 45° F...then dedicated snow/winter tires will provide a much better driving experience...because regardless of the AWD system...if you have tires mounted that can't handle the conditions...then the AWD system can't perform at its best.
    Tires are like "shoes" for your vehicle...the tire's design/type that's appropriate for the conditions...will provide the best experience. Would you run track in flip flops? Would you go to the beach in cleats? Would you go hiking in house slippers? Probably not...but you could...but the experience would not be the best or most comfortable or safe.
    In regards to the engine performance...the numbers speak for themselves...as well as the CAFE gas mileage specs.
    May 2005
    Iowa
    Thanks for the info. It made sense, if I were to get the 4.8is I would probably need a set of snow tires on rims as well.
    1994 325is 5spd
    2004 x5 4.4
    2001 325i sedan
  1. E53 X5 4.6is or 4.8is ???
    By pkortuno in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 12-06-2016, 11:29 AM
  2. M Contour style wheels for sale...great for winter use
    By TRR330xi in forum Great Plains & Rocky Mountains - US
    Last Post: 12-09-2007, 12:47 PM
  3. WTB: 16" Rims for Winter Use E36 (NYC/NJ/LI)
    By @TheWheel in forum Wheels and Tires
    Last Post: 03-20-2007, 09:24 AM
  4. Question: What 17" BMW rims will fit an E39 M5 for winter use, if any?
    By NoSoup4U in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-31-2006, 03:10 PM
  5. Need opinions/advice on alloy wheels for winter use
    By wasabi21 in forum 1999 - 2006 (E46)
    Last Post: 09-26-2004, 03:22 PM
