Results 1 to 7 of 7
Thread: noob here
    Oct 2017
    Chitwn
    96 318is
    noob here
    whats up bimmer folks. new here. as with everything i passionately buy modify a little and move on, i bought myself a 318is.
    manual fourbanger with 143K. with intentions of engine conversion later in the future. i enjoy it and have plans for it. but unfortunately after sometime
    i noticed or heard noises in the rear. everytime i reverse a clunk would sound. this dint happen when i was test driving the car but happened fews days after.
    later found out the right rear strut mount is cracked an inch or two and its been spot welded for some weird reason.no clue what the previous owner trying to do. but
    its repaired just to drive here and there not for long distances so im thinking to reinforce the rear strut mount. need somebody to guide me to the right direction.
    ive seen some reinforcement braces here that people did a fine job with. im not sure if that could suffice the if i have an engine conversion in mind.....
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I will move it to the E36 forum
    Jun 2010
    NY
    1997 328i
    They sell replacement steel, the old gets cut out and the new welded in.
    Oct 2016
    Austria
    e36 323i, M3 3.2
    how about a title that makes sense
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    The e36 doesn't have rear struts. Do you mean the upper shock mount? If that is what is cracked then its pretty much just another steel plate welded over the already repaired crack with the appropriate hole in it so the shock can mount. The reinforcement kits just save you time. They are all the same. You obviously would need those for anything. Since. Ya know. Its already broke.
    -Oakdizzle
    Oct 2017
    Chitwn
    96 318is
    Quote Originally Posted by samy01 View Post
    noobs <----dont make sense... right? anyways...
    Oct 2017
    Chitwn
    96 318is
    Quote Originally Posted by spyderg0d View Post
    yup... thats what i meant. forgot that the spring and shocks are separate in BMWs. i found a steel plate that fit the 318is on partsgeek.com. but encountered another thing, the mechanic says its the differential thats making the clunk sound. not the shocks. i had the car raised on the lift and checked. so now another one to the list. lol... i might as well start collecting M3 parts for the conversion i had in mind.
    you think E36 328i differential would suffice for now or should i just weld that sucker?
  1. hey noob here
    By hakemjmba in forum 1999 - 2006 (E46)
    Last Post: 10-15-2003, 11:31 AM
  2. Noob here....hopefully getting my Cooper S in three weeks!
    By hafid in forum MINI (Cooper & Cooper S)
    Last Post: 06-19-2003, 12:21 PM
  3. noob here....many questions about E36 M3...
    By Jonny Thrice in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2003, 10:26 PM
  4. Noob here with some e36 turbo questions
    By TurboLude7 in forum Forced Induction
    Last Post: 05-19-2003, 04:24 AM
  5. Noob here...NE1 know if Rob Siegel posts here?
    By The HACK in forum Off-Topic
    Last Post: 08-28-2002, 02:14 PM
