My son wants to install a fuel cell on his 82' 320i with the mechanical injection. The fuel pump looks very old and I told him to look at replacing it until I saw the prices....
Question: Is there any reason he cant go with an aftermarket 70psi fuel pump? The factory dual pump setup seems cheesy and expensive.
I have an external inline bosch motorsports fuel pump for sale if interested. Let me know.
http://www.rockauto.com/en/catalog/b...fuel+pump,6256
$105 for a Bosch replacement seems reasonable to me
You definitely have to shop around. Some people seem to think they are worth their weight in gold.
I'm running this one for years , $50/free shipping, Hayg Orig Inline Fuel Pump 0 580 254 909 0580254909 New,,907 sold
Hayg OEM Fuel Pump
- Minimum Current: 12 Volts, Max Power 10 Amps
- Operating Pressure: 72.5 PSI (5 Bar)
- Minimum Flow @ Outlet: 38.9 GPH (148LPH)
- Fuel Pump Connections: Inlet (12MM) (Suction Connection), Outlet (Pressure Connection Thread) (M12 x 1.5), Electrical (Positive M5 / Negative M4)
- Total Length 180mm, Pump Diameter 60mm
http://www.ebay.com/itm/Hayg-Orig-In...53.m1438.l2649
Randy
Thanks all for the feedback.
Thinking of going with a higher flow FP, I'm assuming that any extra fuel will bypass the distributor back to the fuel cell.
I'd grab Bassboys pump, personally.
-John
I still have it if interested
Sent from my SM-G930R4 using Tapatalk
Since the earlier post, I'm now running Bosch Turbine Fuel pump-69430 which is the newest tech on the market with added advantages over old tech fuel pumps , to get higher fuel pressure to the fuel injectors before gas return thru the fuel pressure regulator one adds shim(s) to the pressure regulator in the Fuel Distributor-see faq's-also take into consideration enrichment/lean cycles and its effect on fuel pressure to the fuel injectors, Hayg is a cheaper option, I recommend Bosch 69430 and FCPEuro-with lifetime warranty. Its your choice.
Heres my post on this in case you all missed it.
https://www.bimmerforums.com/forum/s...9430-Fuel-Pump
Randy
