Results 1 to 10 of 10
Thread: Fuse 10 keeps blowing
    Oct 2017
    La Mirada, CA
    1991 BMW 318is Cabrio
    Hello,
    My 91 e30 keeps blowing fuse 10. I've isolated the problem to whatever wire runs from the white plastic connecter beneath the shift boot; When I have that connecter unplugged it doesn't blow. Any idea what might be causing the issue?
    Thanks,
    Alec
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Fuse 10 is for
    ignition key warning/ seat belt warning
    service interval indication
    tachometer, fuel economy gauges
    brake warning system
    back up lights
    OBC, start
    injection electronics
    active check control
    cruise control
    for more details see here http://shark.armchair.mb.ca/~dave/BMW/e30/
    Regina, Sask, Canada
    82 320i 89 325i
    wire is probably frayed under the boot and grounding causing your fuse to blow. it is mostly likely the back up light circuit. sort of common on older cars.
    Oct 2017
    La Mirada, CA
    Hmm, I figured it was a frayed wire, but I've looked under the boot hood and haven't found a thing. Any other locations especially prone to wear? Or easily checked? Thanks.
    82 320i 89 325i
    you might have to remove both the leather and rubber boot under it to trace. the wire passes through a hole in the rubber boot and continues under the car. the reverse switch is mounted near the front of the trans underneath the car and high up. most times you have to get under the car to find and fix the short. 90% sure that's what you have going on.
    pic of the switch from pelican
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    If its an auto trans car that connector also houses the gear selector lock out circuit
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    Oct 2017
    La Mirada, CA
    Hmm, thanks guys. I've gotten the rubber boot out (it's a manual transmission), looks like I'll need to get underneath. Now to find someone with jack locks or some such—it's way too low for me to crawl under.
    Sep 2011
    London
    1990 335i tourer
    Quote Originally Posted by alecd View Post
    I would check the reverse light switch wiring under the boot, if it has come unclipped it can wear and short out on the propshaft or exhaust.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    One trick is to pull one side of the car up on top of the curb. That might get you enough room to go underneath for an inspection. The risk is someone hitting your car while you're underneath. I wouldn't do this on a busy street, but a parking lot or residential street might be OK. It's also best to have a spotter just standing around.
    "Howdy, Folks!"
    Oct 2017
    La Mirada, CA
    Just noticed I never updated this thread—I took your advice and pulled her up on the curb. Found the disconnected wire and patched up, good as new. Thanks guys, sorry for the late kudos.
  1. Fuse #43 keeps blowing
    By LukeG in forum 1992 - 1999 M3 (E36)
    Last Post: 10-04-2022, 12:21 PM
  2. Fuse 33 Keeps blowing!
    By JunzieB in forum 1991 - 1999 (E36)
    Last Post: 06-11-2010, 03:20 PM
  3. Power mirror fuse #24 keeps blowing
    By dsp420 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2007, 12:32 PM
  4. Fuse #15 keeps blowing after H1-H7 fog conversion
    By Blink21Me in forum 1992 - 1999 M3 (E36)
    Last Post: 05-18-2006, 09:14 PM
  5. car wont start and fuse #10 keeps blowing
    By zombiebaby in forum 1983 - 1991 (E30)
    Last Post: 08-02-2004, 10:59 PM
