Results 1 to 17 of 17
Thread: Is head gasket blown?
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    I purchased a 1997 318i from a friend, he says it was overheating, sold to me for $500. Car body and stuff in good shape. Car was sitting for 2 years and not driven. I got the car home battery in it, started right up. Plugged my odb2 sensor in it and connected to my Android phone using odb fusion app, watched the temp on the car, never went over 185f, I drove it around a bit, never rises up. No smoke from tail pipe. I the. Did a cold compression check, 185psi on all cylinders. When pulling plugs out noticed oil in the tubes, so suspected valve gasket leak. I pulled valve gasket off tonight. Attaching photos of the inside of the gasket and the cylinder head too. What do you think? With the look of it, seems the mixture looks like coolant mixed with oil. Should I just replace the head gasket now or just the valve gasket and see after maybe a oil change if the issue comes up? Could it be because sitting so long, that may be why the oil looks that way?
    Sent from my Nexus 5X using Tapatalk
    Oct 2017
    Chile
    E36 1992 320i Sedan
    Its normal as far as i'm concerned, in 2 years the oil get that colour, maybe you'l have to clean it to see if there's a crack somewhere to be sure?
    Oct 2012
    Detroit, MI
    E36, E70, i3
    If it's two year old oil there's probably a decent amount of moisture in it. Change the oil. Drive it, especially with some long highway trips. Check again.
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Quote Originally Posted by Nanniepoo View Post
    Yup, condensation from sitting and not running long enough to "burn out" the moisture
    Oct 2013
    Australia
    Nil BMWs as of 2020
    Vehicles short-tripped in the winter time often get this - its just excess moisture mixing with the oil.
    Obviously, you'll want to change the oil & filter (perhaps more) in a vehicle that's sat unused for such a time. If all your numbers are good, its probably just moisture from sitting. A few long drives will help. I'd be suggesting a dual-rated diesel oil in the 15w40 grade and doing short change intervals for a little while to try and clean things up.
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    Thanks for the feedback.
    Virginia
    97' m52 turbo
    My god,
    Go out and run that car. They love it
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    Quote Originally Posted by 328iFun View Post
    My god,
    I plan on it, trust me! Love the handling of this thing. Drives nice. Just need to replace this valve gasket and all the spark tube seals too. Will be done with that tomorrow and then Saturday will take for the drives and get smog done. Hope to pass that with no issues. Shall see.
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Looks kinda nasty but I wouldn't worry about it too much. Before you change the oil, throw in a little Seafoam or Marvel's Mystery Oil. Drive for a day or so, drain and replace oil and filter. Make sure you get the car nice and hot before smog, and don't turn the car off once you get to the station! Having your catalytic converters up to temp helps a lot with emissions. Check for vacuum leaks and misfires before you go as well.
    Jun 2010
    NY
    1997 328i
    When doing the valve cover gasket be sure to replace the o-ring and gasket seals.
    http://www.realoem.com/bmw/enUS/show...diagId=11_6104
    While your waiting for parts it would be wise to check/replace the coolant to see if any oil isin there.
    You guys are real optimistic, He lives in Cali and you think good oil turns into mustard after two years of sitting.
    mslevin's Avatar
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Quote Originally Posted by Eric93se View Post
    Hope for the best, prepare for the worst
    Jul 2013
    Woodstock, Ga
    1999 M3 - 2013 GSXR 600
    I agree with these guys. It looks to me like moisture from sitting for so long. Change the oil and do a coolant flush. Check for oil in the coolant when you drain it. Could be signs of another problem. Best of luck.
    And $500 is a steal!
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by newman995 View Post
    I'm a major believer in regular Blackstone reports.
    Also, if he reported it was overheating, I wouldn't assume whatever was causing that has just gone away.
    Fan, water pump, thermostat - even just low coolant levels are prime causes. I'd check those things too before hitting the highway.
    And shut it off immediately if the needle climbs past the 12 o'clock position. This time of year especially, if that needle starts to move there's a real problem somewhere.
    Jul 2013
    Woodstock, Ga
    Quote Originally Posted by blckstrm View Post
    I agree with you. It would probably be wise to replace some of those parts if not all of them just to be safe. I am currently trying to fix a cooling issue myself. Its better to spend the cash up front rather than deal with the consequences of major damage caused by overheating.
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    Currently, driving car and no sign of heating issues, talked to owner of the car before again and he said he really never overheated, it started smoking a bit and climbed up in heat just above middle, he thought it was a head gasket issue. I did replace valve cover gasket, spark plugs, and oil. Seems to be running great. One thing notices yesterday, no heat. So, need to figure that one out. Going to drain coolant on Saturday and replace the blue coolant. He put orange in it right now.
    Nov 2011
    Bonney Lake, WA
    1998 328I Sedan
    Be sure to flush the orange coolant out completely before adding your blue. They aren’t supposed to mix well.
    Mike
    1999 750 IL (SOLD)
    1990 750 IL (SOLD)
    1989 325IC (SOLD)
    1995 540I (SOLD)
    1999 323 (SOLD)
    1998 328I 195,000 miles and counting
    2017 Ford Expedition Platinum
    2016 Lexus RX350 F-Sport
    Sep 2017
    Brentwood, ca
    1997 BMW 318i
    Quote Originally Posted by mikeysentra View Post
    Is it best to leave the plugs out and just run water through it until it is clear? I will have to look up the best way to be sure it is all out.
    <br><br>Is it best to leave the plugs out and just run water through it until it is clear? I will have to look up the best way to be sure it is all out.<br>
    <br>
  1. Is my Head Gasket blown?
    By Hvyarms in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-12-2017, 11:54 PM
  2. Is my head gasket blown?
    By Colinoscopy in forum 1991 - 1999 (E36)
    Last Post: 05-24-2015, 03:38 PM
  3. Is my head gasket blown?!?
    By str8trippin in forum 1991 - 1999 (E36)
    Last Post: 03-11-2015, 01:16 AM
  4. Is My Head Gasket Blown ?
    By 36ounces in forum 1988 - 1996 (E34)
    Last Post: 05-02-2013, 08:26 AM
  5. head gasket blown.. is it worth it??
    By egyptnahmed in forum 1991 - 1999 (E36)
    Last Post: 06-10-2007, 03:58 AM
