Results 1 to 8 of 8
Thread: Upper door weather strip between the door and glass question
    Oct 2017
    Pittsburgh, PA
    2004 325xi, 2013 330i
    Question Upper door weather strip between the door and glass question
    Hello,
    My new to me 04 325xi has an issue with the weather strip at the top of the drivers door. It is pulling apart near the side view mirror. The passenger side appears to not be far behind. Does anyone know what the actual name is for this part, or a part number? The window also seems to come "off track", so I guess while I am at it I need to put a regulator in it also?
    Is there any way to upload a pic here?
    Thanks in advance for some help.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Are you talking about #5 here: http://www.realoem.com/bmw/enUS/show...diagId=51_3225
    Or #12 here: http://www.realoem.com/bmw/enUS/show...diagId=51_3253
    One goes around the glass, while the other goes around the whole door.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Oct 2017
    Pittsburgh, PA
    Neither. It is the strip that goes on the top of the metal of the door, between the metal and the window. At the same level as the rear view mirror.
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    I had same problem with my sons 2004.
    here is the part
    http://www.ebay.com/itm/BMW-OEM-325i...lZREha&vxp=mtr
    also to install you can either lube the crap out of the front edge and hope it slides under the mirror or you will have to loosen the mirror assembly from door a bit and install. Be carefull installing it as to not bend it or try to remove it once pressed onto the top of the door.
    Level 1 Certified BMW tech.
    Oct 2017
    Pittsburgh, PA
    Awesome! Thank you. That's it.
    Do you have any suggestion for it seeing like the window is coming off track?
    dworthy's Avatar
    Nov 2010
    Have you ever replaced the regulator? The BMW regulators are made by B.R.O.S.E which means Broken Regulators Our Special Enterprise. While the OEM ones last an average of 10 years, they still last longer than the cheap ones.
    I would remove the window to ease the install of the window guide.
    Darin
    Current:
    Past:
    M-Flight Member
    Oct 2017
    Pittsburgh, PA
    I just got the car on the road a few weeks ago. I guess I should get the regulator and do it all at once? Any recommendations for where to purchase?
    dworthy's Avatar
    Nov 2010
    I like these guys: www.thebmwminipartstore.com
    The are a forum sponsor, and ship rather quickly at a good rate. You can use the P/N from the realoem website, and normally they will get it shipped to you in a couple of days.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Door Foam! The stuff between the door and the panel
    By travbjork in forum 1988 - 1996 (E34)
    Last Post: 07-15-2011, 11:07 PM
  2. Replies: 8
    Last Post: 08-13-2010, 08:14 PM
  3. Replies: 4
    Last Post: 08-31-2009, 11:33 AM
  4. Need driver's door weather strip where is the best place to buy?
    By pgvinter in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2007, 09:20 AM
  5. Door weather strip
    By shadowpuck in forum 1991 - 1999 (E36)
    Last Post: 04-11-2003, 03:28 PM
