This is my 99 M3 vert. I'm coming from a 1996 turbo miata drift car, which I still have, enjoying the BMW so far.
First event with the car. Took it easy to get a feel for everything, the wet conditions made things interesting lol.
Looks like you're out there having a blast! I've always loved seeing verts out on the track.
First event. No cage in a vert. Tandems. Working hand brake.
I'm so confused.
We're OK to run cageless BMW verts here in singles, but sure as hell not in tandem. Maybe it was because of the low track speed?
Side note our last event was on a banked nascar track and there was a kid there in an E36 vert. Mid run for no reason it decided it didn't like the bank and blew the rollover protection out.
Lol If you go fast enough on a bank, the G forces DOWN cause those sensors to go off. The car thinks you're rolling over.
good to see some other verts!
Are those r33 wheels? Looking good!
this m3 looks great
Yes they are, thank you.
Thanks.
Things done to the car so far:
maf, o2 sensors, o2 emulators, cam position sensor, new top, manual top conversion, BC coil overs, clutch master/slave, stoptech rotors, hawk pads, AKG motor/trans/ subframe mounts, condor diff mounts, synchro design works trailing arm bearings, new steering rack/lines/tie rods, recaro sr3, bride fashion protectors, wedge seat rails, 5x114 hub conversion (new hubs/bearings/redrill/studs), R33 gtr wheels, dj auto headlights 6000k hid/ballasts, nardi hub, Nardi deep corn wood wheel, steering column bearing, active autowerke exhaust, 1 piece driveshaft, short shifter (forgot which one, bought it used off a buddy)
DSC_0047 by Jessica Raison, on Flickr
DSC_0434 by Jessica Raison, on Flickr
DSC_0453 by Jessica Raison, on Flickr
DSC_0861 by Jessica Raison, on Flickr
Dat donut box
Remember the good times
DSC_3682 copy by superkamikazee, on Flickr
DSC_3722 by superkamikazee, on Flickr
DSC_3675 by superkamikazee, on Flickr
DSC_4445 by superkamikazee, on Flickr
DSC_4553 by superkamikazee, on Flickr
Please get a cage and a real bucket seat.
Got some work done on the car this winter. Previous owner hacked up the factory audio system and wiring, daisy chained after market speakers together, so that needed to be sorted and cleaned up.
IMG_20180224_211827 by superkamikazee, on Flickr
IMG_20180224_173001 by superkamikazee, on Flickr
IMG_20180224_170600 by superkamikazee, on Flickr
Found that the heater core / hvac unit was shattered and destroyed. The car wasn't blowing heat, took the windshield cowl off and opened up the area where the fans were for hvac and found the damage. So a junkyard unit was sourced and swapped in.
IMG_20180324_143810 by superkamikazee, on Flickr
IMG_20180324_143814 by superkamikazee, on Flickr
IMG_20180324_153921 by superkamikazee, on Flickr
IMG_20180324_153913 by superkamikazee, on Flickr
IMG_20180324_143823 by superkamikazee, on Flickr
Assembled
IMG_20180404_134632 by superkamikazee, on Flickr
Door cards were in rough shape, so new ones were assembled.
IMG_20180205_123939 by superkamikazee, on Flickr
IMG_20180225_001535 by superkamikazee, on Flickr
Recovered the worn arm rest
IMG_20180208_181226 by superkamikazee, on Flickr
IMG_20180208_200208 by superkamikazee, on Flickr
IMG_20180208_203503 by superkamikazee, on Flickr
IMG_20180404_134437 by superkamikazee, on Flickr
Put an 8" sub in the car to go with the new component speakers that were installed.
IMG_20180410_180413 by superkamikazee, on Flickr
IMG_20180424_220101 by superkamikazee, on Flickr
IMG_20180426_131049 by superkamikazee, on Flickr
IMG_20180426_131433 by superkamikazee, on Flickr
IMG_20180426_131454 by superkamikazee, on Flickr
IMG_20180404_134321 by superkamikazee, on Flickr
IMG_20180429_103551 by superkamikazee, on Flickr
Vert by superkamikazee, on Flickr
Jeez, who hosts events that let you do road course tandems with no cage?
Car looks great though, I'm always a sucker for a full interior drift car. It was just too tempting to lose the weight for me!
Just curious - why would you do this to an M3? It's one thing to go drift it - it's another to actually start ripping it apart. By the time you're done with this, it's not gonna be any different than any other gutted E36 with an S52 - and won't be worth any more either.
Why not? M3s aren't special unicorns. They sold a metric ton of M3s. Not vert M3s but the chassis is the same anyway. If you wanna dirt rally a ferrari, go for it.
Gutted? The car has full interior lol, if anything this car was saved. It was a neglected basket case with little of anything left functional, the only saving grace being a rust free Florida chassis found in New England. I've replaced or upgraded almost every component on the car at this point, even restoring the trashed interior. The car was in really bad shape when I bought it, even worse once I got into it and discovered how neglected and how poorly any work the previous owners had done to the car.
Stop and shop by superkamikazee, on Flickr
I've been drifting my turbo miata this season
Lock City Drift Demo 5/6/2018 by Matthew Lee, on Flickr
BMW M3 side by superkamikazee, on Flickr
BMW M3 by superkamikazee, on Flickr
BMW M3 rear by superkamikazee, on Flickr
Track day
worst drift video ever
