Results 1 to 10 of 10
Thread: Issues with GM auto 5 speed.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    2003 E46 wagon 5 speed GM auto...122k. Upon first start in the morning, start the cold engine then wait for the rpm to drop from 1000 rpm to around 700 rpm, about a minute then I put it in reverse and back out of my driveway...then I put it in drive and apply a little gas to move forward.....the car moves only forward slightly so then I apply more gas and only marginally moves forward as the rpm's rise to 2000 rpm and only then does the transmission slowly begin to engage after about 45 seconds. After that, I'm on my way to buy my morning coffee a couple of miles away and the transmission shifts properly, responds properly...and for the rest of the day as if nothing was wrong.
    I have an odd ball BMW transmission. It's not the ZF but rather the GM. According to my research, this particular GM transmission was used in Cadillac and BMW in the early 2000's and is no longer in production. The ATF used for these limited GM transmissions used a specific ATF developed by Texaco, also no longer in production.
    I have not checked the ATF fluid level yet. It seems to me that upon my morning start after putting it in drive that the transmission is starved of fluid...yet in reverse there is no hesitation, the first action demanded from the transmission before putting it in drive.
    Sorry for the long read here but I feel that if explained well here some can understand better what's going on with this transmission issue. Can anyone shed a light?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Have a read.
    And after that get ready for a fluid replacement. That may help or maynot, but it is much cheaper than replacing the unit.
    Attached Files Attached Files
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2017
    Have a read.
    Yes...I've thought about a change to Dexron 6...gotta do the torque converter too! My worry...I have read disaster for GM equipped BMW...wagons in particular 2003....when switched the original TEXACO atf....formulated exclusively for the Cadillac and BMW 3........Lots on the web..............It's better NOT to change atf.....and not because any atf change would distribute debris causing clutch-packs failures.
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    A manufacturing flaw in the forward C1 clutch pack tolerances cause this. Pressure bleeds off overnight. Cold weather exaggerates the delay. There is a EGS update to address this via increasing line pressure but it has mixed success. Same with fluid change. FYI, valvoline maxlife atf is a low cost fluid that is rated specifically for the GM AND ZF trans. Meets all specs.
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    yup, programming and fluid change.
    Level 1 Certified BMW tech.
    Apr 2014
    Northern VA
    e34 m5, touring; e46 (x2
    Quote Originally Posted by dhurley34 View Post
    Take a look at SI B 24 07 03 re: delayed engagement: http://forum.e46fanatics.com/showthread.php?t=1135385 (post 15). I had this issue with my 04 325xit about 4 years ago and the software flash solved the problem (and it has not come back). Good luck!
    EDIT: Sorry for double posting the SIB. I missed it in an earlier post.
    Mar 2017
    YES...all of you support my issue...issues...I don't want to remove and replace the TEXACO..with Dexron 6. The General Motors transmission, the 5 speed furnished with most, if not all, BMW avant...I do have! ...Understand, ATF, automatic transmission fluid...for my 2003 325xi....is, and has not been in production since mid 2000. BMW recommends a replacement in Dexron 6...yet many thousands who have converted report almost instant transmission failure....should sound an alarm here......yes?
    Aug 2014
    Lawrence Kansas
    You're not stating anything that hasnt been stated a thousand times before. Yes the ETL has been out of production for years. The dealer and trans manuf. recommended replacement is Dex-6. I've used it with poor success. It did not mix well with the residual ETL that was left in the trans during the drain/refill and caused harsh 1-2 shifts. I have used Valvoline multi-vehicle Maxlife ATF with GREAT success on multiple vehicles. It is BMW rated as direct replacement for all fluids in the GM and ZF trans. Buy with confidence.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    OP, you might consider a tranny flush to replace all of the fluid. Basically, the shop
    hooks up a machine to the tranny fluid hoses at the fluid cooler at the radiator. In goes new fluid and out comes the old fluid.
    Osnabrock, ND
    we used a trans flush machine, It was shared with subaru on our dealership so we were constantly changing fluid in the thing. but we literally changed thousands of transmission over to dex 6 and no transmission failures. no returns other than the ones that came in leaking for some reason or another (probably poor tech issues) but no failures.
  1. Very small issue with DJ Auto lights and AEs
    By m5hoot in forum 1996 - 2003 (E39)
    Last Post: 02-15-2013, 06:15 PM
  2. Annoying issue with Full auto roof
    By JamboM3 in forum Convertible Questions
    Last Post: 04-09-2012, 07:57 AM
  3. Issue with headlight auto leveling after drop
    By 525iT_Feen in forum 1995 - 2001 (E38)
    Last Post: 05-09-2010, 12:23 PM
  4. having serious issues with e34 6 speed
    By e34rocket in forum Drivetrain & Transmission Parts
    Last Post: 05-26-2009, 10:01 PM
  5. Speed issues with new 330i
    By MeOnline in forum 1999 - 2006 (E46)
    Last Post: 10-09-2004, 01:20 PM
