So people I have opportunity to buy a cheap E32 in perfect condition. Only problem is with transmission, it shifts every gear in 4000rpm. Is it worth fixing or what could be wrong with the transmission. Here are some pics
Sent from my POP3 using Tapatalk
Sounds like stuck solenoids. Should be a fix on Shogun's site for that. Depending on how much, relative to your area, that car has some nice option. It has some nice Style 32 wheels, it has the full rear shade package, and it looks like it has the double thickness window sound deadening package. What is interesting, though, is that with those high end factory options, it is a short wheelbase car.
Black on Black 740i - 10/92 build date, 225,000 miles.
Delphin on Cherry 533i - 4/84 build date, 136,000 miles
Black on Black 328i - 3/96 build date, 185,000 miles - Sold
2008 Porsche Cayenne GTS
well, it can be an easy fix or in worst case a new/used/recon trans is necessary, a gamble. But a fully recon 5HP30 you can get from Germany for under EURO 2000. Check transmission fluid level is the first thing, filter change, how does the ATF look? Does it smell burned and it is black and there are bigger metal particles in the AT pan, then it is a more serious problem.
If it looks just old and 'normal' dirty, change the ATF and the filter and make a proper ATF change at right temperature, with engine running according the 5HP30 instructions. Here done on a 5HP30 on an E38 http://www.e38.org/zf-5hp30-service.html
if that does not help, valve body overhaul, testing all the valves and speed sensor in trans, data here , 11.5MB BMW, AUDI, PORSCHE Technicians Guide http://parts-at.ru/wp-content/upload...Tech-Guide.pdf
SOLENOID AND SENSOR RESISTANCE CHART
solenoid....case connector pin numbers - and +............control unit connecor pin # - and +.........resistamce in Ohms
MV1...........................8 and 12............................................30 and 53.......................................30-34 ohm
MV2...........................9 and 12............................................33 and 52........................................30-34 ohm
MV3...........................4 and 12............................................32 and 52........................................30-34 ohm
EDS 1.........................2 and 12............................................5 and 52.........................................5.2 - 6.8 ohm
EDS 2.........................3 and 12............................................1 and 52.........................................6.2 - 7.8 ohm
EDS 3.........................7 and 12............................................29 and 52.......................................6.2 - 7.8 ohm
EDS 4.........................11 and 12..........................................4 and 52.........................................6.2 - 7.8 ohm
EDS 5.........................15 and 12..........................................51 and 52.......................................6.2 - 7.8 ohm
TOT.............................13 and 14..........................................21 and 22.......................................1000 ohm at 25 degree Celsius
TSS..............................1 and 10..........................................44 and 16.......................................292 - 358 ohm
OSS..............................5 and 6............................................14 and 42.......................................292 - 358 ohm
TSS = turbine speed sensor
OSS = output speed sensor
TOT = resistor in wire
RETREIVING FAULT CODES
A BMW Diagnostic Tool is required to retrieve the fault codes that are stored in the control unit. The diagnostic tool has the ability to retrieve codes, clear codes and activate individual components, and is adaptable to 3 Series, 5 Series, 7 Series and 8 Series vehicles equipped with 4HP-22/24, 4L30-E, 4HP-18FLE, 5HP-18, 5HP-19, and 5HP-30.
