Results 1 to 4 of 4
Thread: Change oil pan gasket
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    My 325i was leaking copious amounts of engine oil for quite awhile. My son was free for awhile so we decided to see if we could fix the leak. The oil was coming from the back of engine. Research indicated oil pan gasket or rear main. We decided to do the oil pan first as probably the easier option. In trying to drop the pan, we disconnected the motor mounts and jacked the front of the engine up using A/C bracket. This was not quite high enough so we lowered the steering rack - still no go. Then we placed a jack under rear bell housing and jacked until the engine was as high as it could go. That worked - no need to remove oil pump or require a special bracket over top of engine. Put new gasket on and put all back together. That fixed the leak!
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    cool.
    No e30s again.
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    Good stuff!
    Dec 2011
    New Zealand
    E30 325i
    I dropped the oil pump when I did mine, it was not hard and kind of good because it allows you to check the mesh filter in the bottom of the pump. Just make sure you torque it back up properly and are careful of oil in the bolt holes messing with the torque spec because you don't want the pump dropping into the pan when you are driving along the road.
  1. Did anyone change oil pan gasket in 528i
    By PENER in forum 1988 - 1996 (E34)
    Last Post: 02-22-2005, 12:14 PM
  2. Changing oil pan gasket help.
    By Road Racer in forum 1983 - 1991 (E30)
    Last Post: 11-27-2003, 10:46 AM
  3. Changing oil pan gasket help.
    By Road Racer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-27-2003, 10:10 AM
  4. Changing oil pan gasket and rear main seal
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 12-26-2002, 08:13 PM
  5. Changing oil pan gasket and rear main seal
    By BMWM3some in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-22-2002, 07:55 PM
