Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
Thread: Front Control Arm Ball Joint Removal/Installation Question
  1. #26
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Quote Originally Posted by LockDots View Post
    Probably need a 20 ton. I was pushing a 20T pretty hard and the bang when it pops out is enough to make you poo a little if you're not clenching in anticipation.
    Put a soft landing pad or something on the floor. And a piece of plywood or the like to protect your privates in case of ricochet. When he says they come out with a bang, he is not overstating.
  2. #27
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I think he's talking about cheaper aftermarket arms. Not worth it. At least, not if you plan on keeping the car for a while.
    are there any? For my 02/98 M3 original p/n's are
    Wishbone, left 31122228461
    Wishbone, right 31122228462
    No matches when I google for aftermarket ones. The cheapo HAMBURG TECHNIC socalled M3 upgrade kits for $160 for the normal E36 show different numbers for the arms
  3. #28
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    I believe Moog and FebiBilstein make some as well. I may be thinking of non-M arms though.
  4. #29
    Jan 2005
    Japan
    Just found on Pelican Parts a pic showing E36 non M and M3 arms side by side showing the differences http://www.pelicanparts.com/techarti...mall/pic08.JPG
  5. #30
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by shogun View Post
    Right and the 318/323/325/328, 1995M3 and E30 Forward Lower Control Arms are the same geometry.
    The 318/323/325/328 FLCA contain an isolated outer ball joint, different outer diameter than the “M” and E30 ball joint.
    There does not seem to be any aftermarket supply for the “M” FLCA except the Meyle which does contain a solid outer ball joint, but the arm geometry only matches the geometry of the 1995M3 FLCA geometry, not the 1996+M3 geometry.
    I believe one could use the 318/323/325/328 solid outer ball joint Meyle HD FLCA with the 1995M3 offset FLCA Bushing on 1996+M3.
    Looks like there might be a MOOG part as well.
    There is a wide variety of vendors offering FLCA replacements for the 318/323/325/328 including (in no particular order) AC Delco, Lemforder (OE), Meyle, Dorman, Febi (Bilstein), URO, Vaico, TRW, MOOG, and others.
  6. #31
    Aug 2002
    Denver, CO
    '98 M3
    I picked up another set of M3 control arms to rebuild. That way I have a spare set and can just swap them out
    '03 911 Turbo 6MT fun car
    '18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
    '15 Cayenne Diesel Wife's DD
    '17 KTM 690 "Adv" 2 wheeled Adventurer
  7. #32
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by DocWyte View Post
    1995m3 or 1996+M3? On to?
  8. #33
    Aug 2002
    Denver, CO
    '98 M3
    96+ for my 96+
  9. #34
    Jan 2005
    Japan
    MTC parts any good? Here are their aftermarket ones for $145/piece for 1996 + E36 M3
    Position Front Right , Cross Reference 1847, 241681, 31122228462, 37106143001
    241681 - Suspension Control Arm - Front Right - MTC $145.95 https://www.wpdusa.com/products/3693...122228462.aspx
    241680 - Suspension Control Arm - Front Left - MTC $145.95, Cross Reference 1846, 241680, 31122228461, 37106142001 https://www.wpdusa.com/products/3656...s=C0%2cC134579
    free shipping for order >$149 https://www.wpdusa.com/
  10. #35
    US
    m3
    http://e36diy.com/e36-m3-replacement...rm-ball-joint/
    Lemforder are ideal, all metal construction.
  11. #36
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    I bent my 12ton hydraulic press arm when doing mine. I have pneumatic press and hid behind my garage while maxing out the 12ton press. It did remove them though with a loud bang! After I looked at the pressing arm and it was bent. Kinda sucks now as anything i press I have to make sure it's going straight.
    In all honestly I would just buy the pre pressed arms from the forum members. I think braymond sells them.
  12. #37
    Dec 2013
    Chicagoland area
    EXOTICS
    I also prefer pre-pressed arms.
    Mitch500, now you have an excuse to upgrade to a 20ton!
  1. Replies: 3
    Last Post: 06-04-2013, 04:35 PM
  2. Replies: 1
    Last Post: 01-31-2008, 09:27 AM
  3. Halp! Control Arm Ball Joint Removal [Pics]
    By Pino in forum 1983 - 1991 (E30)
    Last Post: 06-18-2007, 07:49 PM
  4. Front Outer Control arm ball joint removal-Help!
    By GDawg in forum 1991 - 1999 (E36)
    Last Post: 04-22-2006, 12:39 PM
  5. Lower Control Arm Ball Joint Removal - Help!
    By smuniak in forum 1988 - 1996 (E34)
    Last Post: 09-20-2005, 08:33 AM
