Results 1 to 2 of 2
Thread: Oxygen Sensor 7-12 Cylinder not working
    Oct 2017
    Norway
    1991 BMW 850
    Unhappy Oxygen Sensor 7-12 Cylinder not working
    Hello
    I have just replaced both Oxygen sensor on my 850 after both of them being broken and having engine problems as the engine is not running as clean as it should
    and after being on diagnose test at a local BMW work shop they found that the Oxygen sensor on bank 7-12 still wont work after getting brand new ones
    unfortunately they did not have any more time to check it out and try to locate the problem
    what i have tested out so far my self
    i have tested the cable from the Oxygen sensor to the DME unit and that is whole as far as i can see as i get signal on all the cables running to the Oxygen sensor
    i all so tested out just swapping the DME units for 1-6 whit 7-12 Cylinder whit out no possessive results on that
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Oxygen sensors shall be changed every 80.000 km according to BMW repair handbook. Dependent on manufacturer/quality the sensor can be broken from the start. One way to find out is to switch the sensors with each other and see if the fault follows. BTW I changed my sensors (Bosch) a couple of months ago and there is a noticeable change, less gasoline smell in the exhaust and lower gas consumption when driving.
  1. Oxygen sensor control Bank 2 Not Active error
    By se93 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-11-2017, 04:21 PM
  2. cylinders 5 & 6 not working after installing a new eccentric shaft sensor
    By Munefme in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-02-2017, 08:49 AM
  3. Replies: 7
    Last Post: 09-30-2016, 04:59 AM
  4. several cylinders not working
    By pemacks in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 08-14-2014, 02:33 PM
  5. HELP! cruise control not working-speed sensor not working
    By BiMmEr JoN in forum 1991 - 1999 (E36)
    Last Post: 01-28-2004, 06:43 PM
