Results 1 to 7 of 7
Thread: Passenger window won't go up properly F20
    Sep 2016
    United Kingdom
    f20 1 series
    Hi,
    I'm having an issue with my passenger side window, it won't go all the way up, if I press up it will go half way then goes down again. I have to stop midway then pause then flick it again to close.
    I tried resetting the window, holding the window down for (5, 20, 30 secs) then same when its in close position. But that doesn't seems to work :/
    https://www.youtube.com/watch?v=Bne4elpEeMs
    Any suggestion please.
    Apr 2016
    Philadelphia
    1997 m3
    What process are you following to reset the window? Also what caused this condition? I believe the reset procedure has to be done from the Driver side door switch.
    Sep 2016
    United Kingdom
    f20 1 series
    Quote Originally Posted by Ateyourv8 View Post
    following these steps http://www.1addicts.com/forums/showthread.php?t=247984, as for what caused it I don't really know I left it at bmw dealer for service and when I collect the car it was like that. But when I asked them about it they didn't touch it at all they say. So for them to look at it I will have to pay £99 to diagnose it which is quite annoying. Yes I was doing it from the driver side door.
    Apr 2016
    Philadelphia
    1997 m3
    Sit in car with all doors closed
    Key in ignition
    Roll the window all the way down (not in auto) don't let the switch get to the second click and hold for 30 seconds
    Roll the window all the way up (not in auto) don't let the switch get to the second click and hold for 30 seconds
    Window should be reset and working in auto
    If all fails,i would pull a battery cable off for a little and retry the reset procedure.
    Good luck!
    Sep 2016
    United Kingdom
    f20 1 series
    Key in ignition
    Good luck!
    How's the 2nd step going to work when the window won't go all the way up when I try to close the window.
    Apr 2016
    Philadelphia
    1997 m3
    Sep 2016
    United Kingdom
    f20 1 series
    Thanks its working now followed your steps.
  1. Replies: 16
    Last Post: 03-16-2017, 04:35 PM
  2. e39 passenger window won't go up auto
    By EURO540M in forum 1996 - 2003 (E39)
    Last Post: 11-21-2011, 01:00 PM
  3. Passenger side front window won't go up on "auto"
    By mrwheels in forum 1996 - 2003 (E39)
    Last Post: 06-11-2010, 03:37 AM
  4. Passenger window won't go up
    By JCON328CI in forum 1999 - 2006 (E46)
    Last Post: 05-14-2009, 09:46 PM
  5. My passenger window won't go up!!!!
    By Mrpopaul in forum 1983 - 1991 (E30)
    Last Post: 09-25-2008, 01:33 PM
