Bavarian Soundwerks
Results 1 to 4 of 4
Thread: E36 sedan wire routing from trunk
    Feb 2001
    So Cal
    1997 M3 Sedan
    I'm going to install a new amp in the trunk. What is the easiest route to run cables and wires, along center hump and into console or along the side?
    And is there a trick to getting the moulding off the door sills? Does it just pry up?
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    All modern BMWs gave the audio system cables routed along the left side of the car. Pull the door’s threashold and pull the carpet back a bit. You’ll see a ton of wires in the chassis frame rail.
    Feb 2001
    So Cal
    1997 M3 Sedan
    Thanks Marco. Do you just pry up the moulding at the threshold?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Yup. Be prepared to replace the plastic thingees that hold the threshold in place. They’re pretty fragile as are most BMW plastics.
  1. E36 FS: E36 Sedan Alpine White III Trunk Lid w/ Lip Spoiler....See PICS!!
    By JPanda in forum Exterior Lighting & Body Parts
    Last Post: 03-16-2014, 06:05 AM
  2. best/ easiest ipod wiring route (from trunk)
    By Winter in forum 1991 - 1999 (E36)
    Last Post: 04-12-2010, 01:15 AM
  3. What is the Best Icelink Wire Routing from Trunk
    By z3papa in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-01-2005, 07:04 PM
  4. Best Wiring route from CD changer to cupholder spot? ( ipod )
    By Bham BMW M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 08-20-2003, 06:03 PM
  5. Best Wiring route from CD changer to cupholder spot? ( ipod )
    By Bham BMW M3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-20-2003, 10:12 AM
