Bavarian Soundwerks
Results 1 to 2 of 2
Thread: Amp input rated to 2.5V, can I use a 4V head unit?
    Feb 2001
    So Cal
    1997 M3 Sedan
    I have an older Aura 3005 amp, with input sensitivity rated at 150mV - 2.5V. Input impedance is 10kOhms.
    Can I use a new head unit with 4V output, or should I stick with a 2.5V unit?
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Sending that amp signals as high as 4 volts can result in extreme distortion and potentially damage to the amp. You could use line out converters.
  1. Where can I find an aftermarket head unit that looks OEM?
    By Edgeman in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-11-2003, 04:53 PM
  2. Replies: 0
    Last Post: 07-08-2003, 12:28 PM
  3. can I put subs in my 528i, if I'm using the stock head unit?
    By toofast4U in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-27-2003, 12:54 AM
  4. where can i get an inexpensive head unit?
    By mr wu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-18-2003, 07:53 AM
  5. Can anyone recommend a good head unit?
    By Spubar in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-19-2002, 01:56 AM
