Everything was going great til i tried to remove the hydraulic tensioner pulley on my 99 e46. it wouldn't budge so i grabbed my breaker bar and T-50 and tried to turn it counter clockwise. the T-50 broke! So am i turning it the wrong way or what?
Also, i am trying to replace it with a mechanical one. i removed the long bolt first out of the mounting. It won't thread back in which is weird. Any thoughts on what i should do? I'm hoping if i can just get the pulley off, i can reach the bolt that is behind it, and take the whole thing off.
Thanks in advance for any guidance!
S
No, you turned the torx bolt correctly. Try pulling the bolts out while loosening then.
It won't budge. Should I try some wd40? Don't want to mess things up worse
Well that did indeed work! Thanks for the help!
