Results 1 to 4 of 4
Thread: Throwing 2C31 & 2096 Codes PLZ HELP!?
    Oct 2017
    Grosse Pointe, Michigan
    2010 BMW 535i xDrive
    Hi, my name is Brandon, I'm new here on the forum so please feel free to school me on any etiquette if I break rules or fail to find previously archived threads regarding the same topic.
    Recently (3-months ago) I purchased a black sapphire metallic 2010 BMW 535i xDrive (N54/E60) with just over 100k on it. Got a 24k aftermarket warranty. Ran great at test drive and only needed front brakes replaced at purchase.
    Since purchase I've upgraded/modified the following successfully:
    • Cobb AP Stage 1+FMIC Flash/Map
    • New Front Brake Pads & Rotors (OEM)
    • New Evolution Racewerks FMIC
    • New Evolutiom Racewerks Charge Pipe
    • New HKS SSQV Blow-off Valve
    • New Spark Plugs (OEM)
    • New Injen Dual Cone Air Intake
    • New Low Pressure Fuel Sensor (OEM)
    • New Electronic Water Pump (OEM)
    • Chemcal Engine Flush
    Obviously the tune-ups/fixes/upgrades/modifications were expensive — but I wanted to increase my HP & torque and make sure the engine was breathing correctly (had enough air intake for added power via chip + mods) and all issues were addressed.
    She was running like a raped ape all day today and then while I had her Cobb chipped she started sort of bouncing or hesitating on aggressive acceleration and then throwing codes P2C31 (at first) and then P2096 in addition (later on, after I uninstalled Stage 1+FMIC maps).
    Now the check engine light is on (with no flash) and the Cobb AP is consistently giving me those 2 codes?!
    P2096
    P2C31
    CAN ANYBODY PLEASE HELP?
    I am a new and first time BMW owner and would appreciate anyone's time/feedback who may have experience with the issue! Thank you in advance.
    Brandon
    Dec 2013
    Chicagoland area
    EXOTICS
    P-codes can be notoriously unreliable, even though I suspect an intake leak,
    Have a diagnostic scan performed with a BMW specific scan tool/software.
    Dec 2013
    Chicagoland area
    EXOTICS
    Btw, double check that O2 sensors were installed correctly,
    so that bank 1 & 2 sensors and connections are not X'd,
    As I've read that is a possibility in your situation.
    Oct 2017
    Thank you so much for the reply, I'll have my mechanic check front & rear O2 sensors!
  1. Code P1622...plz help!! where do i start?
    By lensf415 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-23-2007, 10:13 PM
  2. [B]CEL ON ... THROWING 2 Codes ... NEED HELP[/B]
    By M3/4 LIFE in forum Forced Induction
    Last Post: 06-29-2005, 10:03 PM
  3. E36 Amp Wiring Codes...
    By Kevlar in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-07-2002, 04:51 PM
  4. Plz help me diagnose this awful squeak
    By meekay in forum 1991 - 1999 (E36)
    Last Post: 10-11-2001, 04:40 AM
  5. SoCal people: where can i buy perf. parts locally? plz help!
    By pikachu in forum 1991 - 1999 (E36)
    Last Post: 09-27-2001, 04:08 PM
