Results 1 to 2 of 2
Thread: How to Get the Most out of Your BMW’s Engine
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    Lightbulb How to Get the Most out of Your BMW’s Engine
    BMW has always been known for powerful, high-quality engines, but no engine will keep running forever without a bit of maintenance and some TLC. What do you need to do to get the most of out of your new or new-to-you BMW engine? Change Your Oil Changing your oil is one of the most important … Continue reading How to Get the Most out of Your BMW’s Engine →
    See more at www.bimmerforums.com - The Ultimate BMW Forum
    More...
    Jan 2016
    Ca
    2001 525it
    I would change the oil every 5k. Pop the hood and check check fluids every couple of weeks. Change the spark plugs a little sooner than required. My e39 has the low cluster so no coolant light, but it does have low washer fluid light!? So check that coolant often and dont over heat the engine ever. Flush your. Brake fluid every two years and power steering fluid when it starts getting dirty. When starting your car, let the engine idle a few mineres before tearing off. This very important on turbo cars, also for turbos let the engine idle a bit before shutting off it will bring cooler oil to the turbo bearings.
  1. How to get the most out of s52 us model
    By 1FRacing in forum 1992 - 1999 M3 (E36)
    Last Post: 03-27-2012, 10:55 AM
  2. How to get the most out of my 318i?
    By mgshiva in forum 1991 - 1999 (E36)
    Last Post: 10-20-2008, 01:46 PM
  3. How to get the most out of my 318
    By Aequitas in forum 1983 - 1991 (E30)
    Last Post: 03-07-2007, 01:43 AM
