Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: M70 chips
  1. #26
    Sep 2010
    Finland
    bmw 850i M-tech
    I would sure love to see an acceleration video of TxGR8Whites car...
  2. #27
    Orlando, FL USA
    Quote Originally Posted by TxGR8White View Post
    I looked at the video and it seems that your car is a bit sluggish, mine definitely has quicker acceleration and shifts a bit quicker. I would look at the following:
    1. fuel injector condition
    2. spark plugs (if you are using anything other than plain copper plugs, you are wasting money and getting poorer results (the ignition system does not have the required voltage for platinum, iridium or other newer style plug)
    3. fuel delivery - strainer in the tank clogged?, fuel filters clogged? fuel pressure regulators weak.
    4. vacuum lines to FPR - are your vacuum lines brittle or old?
    5. condition of DK motors - if the butterfly doesn't "snap" back when manually opened all the way, but rather acts a little slow, they may need cleaning/refurbishing.
    6. air filters - are they new or are they dirty?
    7. lower airboxes - are your airboxes in good condition? if you have rips, holes, or other things that allow air to escape before it reaches the engine, you no longer have the cold air (and partial ram-air) effect needed.
    All of these things contribute each in a small way, but when you have several of these problems, you will notice a decrease in performance.
    Good luck, and let us know what you find out.
    +8
  3. #28
    Jul 2015
    Helsinki, Finland
    1991 BMW 850
    HI,
    I was the other 8er, while we compared our cars with Mikae31.
    My feelings are, that in slow speeds difference was big in slow speeds, but in highway speeds it was hard to feel the difference. Maybe some day (after winter) we can make some videos from 0 to 100 km/h.
    From 80 to 220 km/h is the true life, but due to greedy polices of Finland it's very hard to find a safe place to do that. Next summer I can make it in Germany, but Mikae31 is not on same road trip. In Mikae31's car fuel consumption was almost 50% more, mainly due to 3.91 differential, I suppose. Because none else haven't reported about big raise of fuel consumption.
    Seems that there are no proven data available to see true differences between standard (like my E31) and chipped (Wokkw, Dina, someone else) ones, or are there?
    Anyway, dos anyone know how Alpina B12 coupe 5.0 got its 350 hp?
    With new chips or with mechanical & chip changes?
  4. #29
    Sunny Cali,
    6.5 second 69 Camaro
    Alpina is always mechanically included to up there Hp
  5. #30
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    a lot of mechanical engine/drivetrain parts on the B12 Alpina are different, for example
    Kolben A/B 84,000 - 84,010mm Zyl.1-6, 11 25 695
    4 Kolben A/B 84,000 - 84,010mm Zyl.7-12, 11 25
    2 x cylinder head 11 12 617
    cylinder head gaskets
    outlet valves dia 36mm
    both camshafts
    inlet valves dia 42mm
    exhaust (especially the cat system)
    1 Schalldämpferanlage kurz 18 10 707
    1 Schalldämpferanlage lang 18 10 711
    2 Abgasrohr Zyl. 1-3 11 76 1 716 361
    2 Abgasrohr Zyl. 1-3 11 76 1 716 365
    3 Abgasrohr Zyl. 4-6 11 76 1 716 362
    3 Abgasrohr Zyl. 4-6 11 76 1 716 366
    4 Abgasrohr Katalysator rechts 18 10 724
    4 Abgasrohr Katalysator rechts 18 10 774
    4 Abgasrohr Katalysator rechts 18 10 738
    5 Flansch 18 11 1 712 393
    6 Dichtring ø72mm 18 11 1 723 538
    7 Abgasrohr Zyl. 7-9 18 31 1 716 773
    7 Abgasrohr Zyl. 7-9 11 76 1 716 367
    8 Abgasrohr Zyl. 10-12 18 31 1 716 774
    8 Abgasrohr Zyl. 10-12 11 76 1 716 368
    9 Dichtung 11 76 1 711 717
    10 Mutter M10 07 29 101 10
    11 Abgasrohr Katalysator links 18 10 723
    11 Abgasrohr Katalysator links 18 10 773
    11 Abgasrohr Katalysator links 18 10 739
    software for Motronic, EML, AGS, EGS
    Note: the part numbers are from the E32 Alpina B12
  6. #31
    Sep 2010
    Finland
    bmw 850i M-tech
    It's good that alpina b12 coupe was brought up to this discussion because basically it proofs my point.
    Like everyone knows Alpina has done many changes to their cars and we all know that b12 coupe has 350hp. Also we know that alpina has changed the diff to 3,45. What everyone should think off is that alpina promises b12 coupe to accelerate from 0-100km/h in 6,8s. That is the number we can rely on.
    Now, it was tested, and posted here also, that my car accelerates 0-100km/h in sharp 7s. It is stock m70b50 with wokke V2 chips and 3,91 diff. This is only 0,2s more than what alpina promises to b12 which by all means is much more performance tuned vehicle. So basically what some of you are saying is that with these little mods like wokke V2 and 3,91 diff the stock m70b50 auto should become an alpina killer? I'm sorry guys but i don't buy it.
    So until someone with exact mods makes a video, like mine, where you can clearly see that the car accelerates better i don't believe that there is anything wrong with my car. I strongly believe that this is what you can get out off your stock m70b50 auto with these mods, and it's not that much.
  7. #32
    May 2013
    Calgary
    1990's BMW dealership
    I went back and looked at your original 0-100 km video. You don't actually get wheel spin until 4 seconds, and you cross 100 km on the speedo at just over ten seconds. You are less than 7 seconds (I'm guessing about 6.8) and that is damn good for a 90's era luxo barge at near 2000 kilos. The same year M3 was 7.3 seconds and the M5 was 6.3. Further to this, these weren't built for drag strip performance, they were built for sustained high speed operation. 4 hours in an 850i on the autobahn at 200+ km/h would be a totally different experience in comparison to a M3 of the same year and same speed.
  8. #33
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    50% increase in fuel consumption for little increase in performance = something badly wrong!
    My BMW Repair YouTube Channel
  9. #34
    Sep 2010
    Finland
    bmw 850i M-tech
    No, NOT 50%, about 3l/100km compared to car with 3,15diff.
  10. #35
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by mikae31 View Post
    Quote Originally Posted by Hantte View Post
    HI,
    I was just going by the previous posts, but, as you are happy with your performance and fuel consumption then best not pursue it any further.....
  11. #36
    Sep 2010
    Finland
    bmw 850i M-tech
    No, i'm not happy. Not performance and not fuel consumption. I thought i had made it pretty clear. I understand that this is propably the best you can get out of your stock m70 with these relatively small mods. And that's fine. However the radically increased fuel consumption is a shock. So many times there has been discussion of how big improvement it is to install 3,91 and Wokke V2. Well i have experienced it now and because of so huge effect in fuel consumption i don't think it is worth it. I believe it is the short diff that is mainly the reason for this huge consuption.
  12. #37
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Going from 3,64 to 3,91 in USA isn't that great of a change in ratio or MPG....but makes me smile a lot. Even in California where petrol is more costly.
    1993 850Ci.....18 years & 165,000 miles and counting!
  13. #38
    Sep 2010
    Finland
    bmw 850i M-tech
    Quote Originally Posted by TedBobo View Post
    Propably not, but going from 3,15 to 3,91 is.
  14. #39
    Indianapolis, IN
    True that!
  15. #40
    Sep 2010
    Finland
    bmw 850i M-tech
    https://youtu.be/Ntq2wKkcxKM
    this is video that i found. It shows stock car with 3,91 installed and acceleration is way better than mine. I measured that several times and i actually got under 6 seconds acceleration times from 0-100km/h!! About second faster than mine with Wokke chips installed. So now i need to figure out what the hell is wrong with my car
  1. Wokke chip EML V2 850i M70
    By didchris in forum Parts for Sale
    Last Post: 05-26-2016, 08:15 AM
  2. New M70 Shogun chips; New O2 sensors; 850i Ran great; stranded- SOLVED
    By EEDegreeToDrive in forum 1988 - 1994 (E32)
    Last Post: 09-20-2011, 10:07 PM
  3. How to: EML chip install M70 engine
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 02-16-2011, 09:08 AM
  4. To all M70 owners: new advanced EML chip available
    By wokke in forum 8 Series (E31)
    Last Post: 10-23-2009, 08:47 PM
  5. FS: Dinan Performance Chips, M70 V12
    By chicagov12 in forum BMW Parts For Sale
    Last Post: 02-09-2007, 08:33 PM
