The FCPEuro relay is a drop-in replacement for the standard Orange 4-pin relay, the fifth pin is not used
My BMW Repair YouTube Channel
Does anyone know where I can find a color pic of the inside of the E-Box? I've tried searching and got some pretty strange results, but nothing helpful. Yeah, BMW, in their infinite wisdom, has superseded their relays and apparently changed colors, however I need to know what was originally installed as the fuel pump relay. As I said earlier, one fuel pump relay is blue the other pale green, neither of which (seems) to match the relays you guys are talking about. I tried finding it in the ETK, however it doesn't list a description of the relays in most instances as to their use.
Thanks,
Mike
Mike Drives:
BMW's
E24 - 635CSiA - (1) 1985 (US)
E24 - 635CSi - (1) 1985 (EC)
E31 - 850iA - (1) 1991 (Black)
E31 - 850iA - (1) 1991 (Calypso Red)
E32 - 740iA - (1) 1994
E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
E32 - 735iL - (2) 1990
E32 - 750iL - (1) 1990
E38 - 740iLA - (2) (1) 1997 & (1) 1998
E38 - 750iLA - (1) 1998
E38 - 740iA - (1) 2000 "Short Sport"
E39 - 528iA - (2) - 2000 & (1) 1997
Also:
2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
2014 Dodge Dart Rallye (Daily Driver)
2007 Mercedes Benz CL600 (Brabus SV12S)
Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
1967 Buick Riviera (2)
Although I have a picture of the E-Box, I've got a V8 and that is completely different - the best I have is from the ETK:
http://www.meeknet.co.uk/e31/Timms_B...lay_Finder.htm
Thanks Timm, but I need the e-box with the EML and DME's in it. Where the FP relays are.
Thanks again
Scroll down - the E-Box for both the V8 and V12 will be found there!
I need the color of the fp relays. If I saw you're diagram correctly, it's in black & white.
Thank you though
Mike
Use the ETM by built year, there are all the relays shown and their location http://shark.armchair.mb.ca/~dave/BMW/e31/
Finally!
After (literally) months of being side tracked by other cars, I finally had a chance to concentrate on the 850. There was a broken wire in the Cylinder ID connector for 7-12 which was causing the fuel pump not to come on.
Bottom line - if you have a problem, keep digging - all the way to China if need be. These friggin' cars are worth it!
Thank you to all who helped! Without you guys, this car would have probably lounged around in my shop for another couple of years.
You guys are the best!
Mike Drives:
BMW's
Also:
