Hi,
I'm selling my 1997 328is Spec E36 BMW CCA Club race car. I'm gotten into dual sport motorcycling and haven't had time to take the car out on the track. For fast response, feel free to text me at 202-803-3123 and discuss further. I originally purchased the car because:
Pictures are below. Price is fixed: 11k (Located in McLean, VA)
-Faster than a Spec Miata
-Newer than an e30
-Less expensive to maintain than an e36 M3
-More reliable than an e46
-Way less expensive than an e46 M3
-Cheap expendables for brakes and tires 245/40/17
The car is perfect instructor for NASA and SCCA events. The race car now has two seats (Ergo GRP tech) and was professionally sorted out by at shop in Richmond, VA. You can either use this car to race and/or instruct (even enduro races).
The car is professionally built and comes with a lot of details (see below). Please text me anytime at 202-803-3123. If this ad is viewable, the car is for sale. Thank you.
Notes:
(I may consider a trade for an e46 M3 with track mods, especially Mystic Blue)
I'm willing to reduce pricing based on things you don't need, seat and/or tires
(2 track days on brand new DUNLOP DIREZZA ZII STAR SPEC on Kosi K1 racing) - $1000 spent less than two months ago
Details:
This car won 2nd place in the Championship in 2012. 124k on the engine (this was a huge plus for when I purchased the car)
Chassis
Custom Cage prepaired by Piper Motorsport:
Fabricate E36 roll cage. NASA rear w/ diagonal
X door bars
Diagonal roof bar
Weld right side net tab in dash
Drill inspection holes on passenger side of roll cage
Custom driver and passenger seat mount rails
Custom harness eyelets
Sparco Tech seat
Sparco side mount brackets steel
Sparco universal seat rails
High impact roll cage padding
High impact roll cage padding mini
G-Force Mesh Net SFI 2 Layer
SPA Design 12 foot pull cable
AMB Transponder TRANX260
1.5x.120 DOM tubing
Window net (mesh) 18x24
Window Net mini Latch & Link kit
Piper Motorsport Center Net Restraint System
Weld in factory sunroof to comply to BMWCCA Club Racing rules with tabs
Rear subframe reinforcement kit
Billet AL engine mounts
Billet AL Transmission mounts
Through firewall grommets for dry sump hoses
Kill switch
2 tow straps
hood pin kits
Batter box & hold down kit
Turner Motorsport E36 oil pan baffle kit
Head & porting work (1mm larger intake valves with extensive port works)
Block & crank prep etc. . .
DLC coating of cam shafts
Fuel injectors cleaned by Mr. Injector
precision wrist pins
upper end gasket set
Valve chain tensioner
chain guide rail
K&N air filter
chain guides
chain guide rail
Engine Management & Instrumentation (machine work done by Justice Inc.)
Engine has been rebuilt every 4 races. Always used Motul.
Head Bore to first overbore
Crankshaft balance
Port and polish
Angle valve job
Head blueprinted
Intake and Exhaust valves blueprinted.
Shark Injector
Autometer water temperature gauge
Autometer oil temperature gauge
BMPD design Oil Pressure sender
Exhaust
Longacre header wrap 50' x2"x1/32 black
Longacre SS 8" header wrap ties
Custom exhaust
Meets BMWCCA sound ordinance
Suspension :
H&R E36 RSS Club Sport Coil over kit ( E36 Nurburgring matched springs and dampers, adjustable ride height)
UUC Sway Barbarians
BMW CCA Club racing fixed camber plates
Front upper strut bearings BMW part # 31-33-2-228-345 ( 95 BMW M3)
BMW part # 31-33-1-110-196 dust protection collar
BMW part # 31-33-1-116-983 flat washer
UUC Urethane Rear Trailing Arm Busing ( RTAB)
Tuner Motorsport E36 rear subframe race mount solid
Delrin offset control arm bushings race only
Brakes & Steering
Brembo front brake disc rotors
Brembo rear brake disc rotors
Hawk Black front brake pad
Hawk 9012 rear brake pad
Earls stainless steel brake lines
Motul 600 race brake fluid.
Wheels
1 set of tires for trailer transport.
2 track days on brand new DUNLOP DIREZZA ZII STAR SPEC on Kosi K1 racing : rim width 8.00 to 9.5 17x8.5 5-120 (245/40R-17 )
VAC-WS-DL-70 Dry Lube Wheel Stud
VAC-WN-17 Wheel nuts 12 x 1.5,17mm
VAC 15mm wheel spacers set
Interior
Roll Bar padding
Window net
Carbon fiber center dash
