eBMWParts
Results 1 to 4 of 4
Thread: Is having compression and rebound tied to one adjustment a good or bad thing?
    New England
    E36 M3, E39 M5, E34 525i
    I see that there are some options like TRM that have the compression and rebound tied to one adjustment knob. I don't understand how this could be a good thing. The way I understand it is that compression is more a function of the car itself (unspring weight etc.) where the rebound is how you tailor the setup to the specific spring rates you have. Is this correct?
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I have single-adjust compression/rebound dampers on the front end of my E36 track car, and single adjustable rebounds on the rear. I don't know if the front adjustments are better than rebound-only, but they aren't screwing anything up. If I bought high-end coilovers I would definitely get separate adjustments for compression because I run on some smooth tracks and also some really rough ones at times. Also it's nice to be able to adjust dive balance from both ends of the car, instead of just the opposite end.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    ATL
    '91 325i
    Piston design and ratios of valve stiffness dictate how much "cross talk" a damper may have. If the adjusting knob changes compression too much, there is a fundamental design error with the damper. In high end single adjustable mono tube shocks, the entire adjustment range of rebound will have about the same change on compression as one click does on rebound. Penske has versions with extra one way valving that eliminates this altogether.
    Twin tube design has no cross talk and at the price you are looking at, I think the KW V2 are fantastic.
    Aug 2011
    Charleston, SC
    95 E36 M3, 03 E39 540i6
    This is a good question.
    In my opinion Koni gets it right with single adjustable shocks by only adjusting rebound. This is why you can match them with relatively stiff springs. When both rebound and compression go up compression can become too stiff (exactly what was alluded to above).
    A dual adjustable shock is more desirable, also a lot more expensive.
    Iíve used single adjustable monotubes in the past that adjust both at same time, for the spring rates they were designed for they work great (PSS9 etc). Itís when you want to tweak the spring rates up, then a single knob adjusting both can be an issue as you canít independently adjust bounce.
    Edit to add KW V2ís are excellent coil overs!
    PCA HPDE Instructor
    1995 BMW M3
    2003 BMW 540i6 Alpine White M sport
  1. This bug is biting me, and I want to buy one...
    By telijah in forum 1992 - 1999 M3 (E36)
    Last Post: 05-21-2006, 04:28 PM
  2. X-brace where is the best and cheap place to buy one.
    By CrazyINP in forum 1992 - 1999 M3 (E36)
    Last Post: 02-28-2006, 02:48 AM
  3. HELP!!! my car is so slow and i need to fix it
    By a32guy in forum 1991 - 1999 (E36)
    Last Post: 08-30-2005, 07:20 PM
  4. help needed in adjusting compression and rebound
    By ChewToy in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-11-2005, 12:04 PM
  5. Where Is The Best (And Cheapest) Place To Get V1 Mirror?
    By ArcaneParadise in forum Off-Topic
    Last Post: 09-09-2003, 02:24 AM
