Lately every time I start the car ('04 325ci cpe) it seems that the electric fan comes on right away...the car isn't even to operating temp and the fan is going. It is pretty loud too, I thought there were two speeds to the fan, mine seems to only have one speed high/loud. (Is this a problem?)
I'm having both the driver and passenger airbags replaced (under the Toccata recall) maybe I can ask that they do a diagnostic check
The relay might be bad causing a short or the sensor could be bad also. unplug it, if the fan stays on it more than likely is the relay. Short the harness for the sensor, if the fan comes on your sensor is bad.
ME:"I want to make my car faster and lighter"
THEM:" Get out and let someone else drive"
Thank You BaliDawg & MarcoZandrini , your responses most helpful.......it also explains the related A/C problems too.....
You’re welcome. We’re all in this sweet addiction together!
