BMW of Bloomfield
Results 1 to 17 of 17
Thread: Selling my swap - 1999 LS swapped e36 M3, low miles, minty inside
    Nov 2008
    nnj
    Vipers, e46m
    This is going to be long. I never really thought I'd sell this car. I've owned it for 7+ years and it has been the most fun, best thing I've done thus far in life. However, after a recent back injury, coupled with the fact that I barely ever had time to drive it anyway, I feel it is time for someone else to enjoy this awesome beast I've built. It has been complete for over a year and has been loads of fun.
    This is not your slapped together, just-get-it running build. I took my time to build this right. I have a ton of pictures of all of the progress that I would be happy to share with the prospective next owner. Even if you are not interested in purchasing and just want to come check the car out, by all means let me know. I'm very proud of this car and how it turned out.
    $nevermind, i'm keeping this thing till forever.
    No test drives, serious inquiries only.
    1999 BMW M3
    Artic Silver
    ~92k miles
    Sunroof
    Manual Vaders, no rips or tears
    Autoclimate
    Owned since 2010
    Legally passes NJ DMV Inspection!
    Engine:
    1998 LS1
    LS6 Intake Manifold
    Ported Throttle Body
    LS6 Valley cover
    Modified factory steam vent
    Factory truck oil cooler manifold to Mishimoto 9 row cooler in kidney grills.
    MSD ignition wires
    NGK plugs
    New LS1 timing chain kit
    New rear main seal
    New gaskets throughout entire engine.
    Improved Racing Oil Pan Baffle
    Improved Racing Crank Scrapper
    Modified CXRacing engine mounts
    Modified CXRacing transmission mount
    CXRacing headers, professionally ceramic coated.
    Full stainless 3 inch exhaust, all v-banded
    Magnaflow 3 inch CAT
    Magnaflow 12198 muffler
    LS2 “truck” MAF, 85mm Delphi
    Corvette fuel filter/pressure regulator
    Wiring Specialties harness
    K&N filter
    Dyno tuned with HPTuners – 360whp/358wtq
    Drivetrain:
    2001 WS6 T-56 (55k miles)
    New factory LS7 Flywheel, Clutch and Pressure plate.
    ARP Flywheel bolts
    New factory throwout bearing with remote bleeder setup & custom lines with quick disconnect for easy removal from the car.
    New ACDelco Pilot bearing
    MGW Shifter
    Modified reverse lockout spring
    New factory trans mount bushing
    Custom driveshaft professionally made and mated to JTR 1310 U-joint differential flange.
    Fully rebuilt 3.91 LSD – new clutches, new bushings, upgraded M14 10.9 grade differential bolt.
    Other:
    Solid steering shaft u-joint
    Lokar throttle cable setup
    New Turn One power steering pump (won’t overheat like the factory unit).
    AN power steering lines
    AN Fuel line – Fire sleeve protected
    AN Oil cooler lines
    AEM Wideband O2 sensor
    Custom 3d printed gauge panel
    Schroth 4 point clip-in harness, passenger and driver.
    Autometer Oil and Water temp guages - wired in but not connected.
    Heat reflective tape lining entire trans tunnel
    Chassis:
    Dinan front strut bar
    Modified lower X-brace
    BC Racing Coilovers & Camber Plates
    BC 550# front springs
    H&R 650# rear springs
    Turner Motorsports rear swaybar
    Because this is a '99, it has factory subframe reinforcements.
    Cooling:
    Koyorad all aluminum oversized rad.
    16” Spal puller fan
    Custom shroud
    Custom front duct.
    Custom coolant lines to auto climate heater control and remote reservoir.
    Wheels:
    Enkei RPF1s - 18"
    Hankook Ventus V12 245/35r18s all around
    Brakes:
    PFC 06 brake pads
    Motul 600* fluid
    SS brake lines front and rear
    Bad:
    No AC. I didn’t do the retrofit for AC with the swap. The condenser and lines will be included with the sale if wanted.
    This was a salvage titled car from an accident back in the early 2000s. The car was hit in the left rear and completely and professionally repaired by BMW themselves. The chassis is perfectly straight, aligns perfect and has always driven like it should.
    The clearcoat is beginning to flake at a few seams under the windows/top of doors.
    Tiny bit of bubbling starting just above the windshield (pictured).
    Extras not included in the sale price:
    Set of original staggered DS2s.
    Please follow this link for an album of pictures:
    https://flic.kr/s/aHsm6qBMJV
    Nov 2008
    nnj
    Vipers, e46m
    Bump.
    Nov 2008
    nnj
    Vipers, e46m
    I've had a few interesting offers but nothing solid yet. Not really looking for a trade, just looking to sell.
    Open to some serious offers though.
    Dec 2014
    Phily, PA
    95 M3 LS6
    Very nice car! I miss my LS6 M3...perfect combo in my opinion. GLWS
    -Chris
    02 540iT LS2 || 13 550XI Msport || 94 530i || 04 330ci || 92 Galant VR4 || 94 Supra TT/6 810whp
    Nov 2008
    nnj
    Vipers, e46m
    Thank you!
    Nov 2008
    nnj
    Vipers, e46m
    Price has been dropped.
    Apr 2008
    Long Island ,NY
    95 M3 , 99 Z3 Coupe sold
    if my Z3 coupe that's for sale on here sells, ill be all over this ..love it
    I'm an Aussie living in the States , love it
    Modestly dyslexic so for give the spelling.
    Nov 2008
    nnj
    Vipers, e46m
    ^Nice.
    Nov 2008
    nnj
    Vipers, e46m
    Car is in hibernation mode now. Tender and cover on.
    NY
    skateboard
    Love the wheels. GLWS
    Nov 2008
    nnj
    Vipers, e46m
    Still in storage, but Spring is coming...
    Dec 2014
    Phily, PA
    95 M3 LS6
    Sell it on Bring A Trailer in the spring...you'll get better results there.
    -Chris
    Nov 2008
    nnj
    Vipers, e46m
    We had one half decent weather day here and I couldn't resist, so I took the car for a spin. While it was out I figured what the heck and installed the dent free driver side fender.
    It's back on the battery tender and sleeping under a cover for another few weeks.
    Nov 2008
    nnj
    Vipers, e46m
    Price drop
    Nov 2008
    nnj
    Vipers, e46m
    Lots of pictures added to pic link: https://flic.kr/s/aHsm6qBMJV
    Dec 2015
    westchester
    2011 E92 m3
    Hello interested, possible you can text me? thank you. 914-659-7588 - Nick
    Nov 2008
    nnj
    Vipers, e46m
    Car just passed NJ DMV inspection this weekend.
  1. Selling my swap - 1999 LS swapped e36 M3
    By pMak26 in forum Engine Conversions
    Last Post: 10-03-2017, 08:28 PM
  2. E36 1999 E36 M3 Low Miles
    By rtbittaker in forum 3 series & Z Series
    Last Post: 04-07-2013, 06:39 PM
  3. Selling my AA Stage 2 '96 E36 M3
    By '96 E36 M3 in forum Forced Induction
    Last Post: 12-10-2012, 09:46 AM
  4. 1999 e36 m3 low miles
    By RedBoomer ///M3 in forum 3 series & Z Series
    Last Post: 09-16-2009, 11:01 PM
  5. Thinking of selling my E39 and getting a E36 M3. Thoughts?
    By Austin TTZ in forum 1992 - 1999 M3 (E36)
    Last Post: 10-25-2002, 03:08 PM
