Results 1 to 12 of 12
Thread: E36 m3 compatible with e90 m3 parts?
    May 2017
    Overton
    1998 bmw m3
    So I've been looking into used parts but there isn't Much in terms of e36 m3 in my area but there is a lot of e90 m3 parts. So I was wondering if parts like suspension parts can be used on an e36 m3 from a e90 m3
    Oct 2003
    Seattle
    99 M3
    I think the strut spring "hats" offer a 1" drop and fit the tops of 1995M3 and 318/325/323/328 springs
    May 2017
    Overton
    1998 bmw m3
    You sa it would fit a 95 m3. Would it not fit a 98?
    Florida and ATL
    1999 M3 and 1990 Jetta G
    motor mounts can be used.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Basically nothing.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Charles1313 View Post
    1995M3 and 1996+M3 have different front spring upper diameter/spring rate. These two variants do not share same front spring (upper coil diameter) or spring "hat".
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Quote Originally Posted by bluptgm3 View Post
    Has this been confirmed by anybody? Looking to further lower the front end of my '96 328, but don't want coil overs.
    Thanks.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by Mless5 View Post
    Thanks.
    I can't speak to the 328, but they require modifications to the strut hat to work on '95 M3 springs.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by nick325xit 5spd View Post
    Vorshlag should know. Their camber plates are the same for E36 and E9X, though there are some options you have to sort out when you buy them due to the pre '95 and 96+ differences. But they could say with a pretty good degree of certainty the differences between E9X and whichever E36 the OP has (328?).
    Aug 2013
    1999 BMW M3 Coupe
    Back to the OP, no there isn't really much commonality in terms of OEM or aftermarket parts. It's a different car built on a different platform. You'll find common things here and there like motor mounts or certain aftermarket things like camber plates maybe (and probably bunches of little fasteners), but the dimensions of the car are much different and the parts that compose it were designed just for the E9x. Same can be said for any generation really. Some were a bit closer to than others, especially the older generations, but nowadays car platforms are basically reengineered from the ground up each time a new one comes along. The E9x is also significantly larger/heavier with more power, so the suspension and driveline all has to be reengineered for those requirements.
    TLDR - Go to realoem.com and commit it to memory. It's super easy to see what parts go where and on which models/generations there.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by TostitoBandito View Post
    Note that the E36, for the “Catalog” pull-down, is in the “Classic” selection.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    It's not even a dimensional issue. The fundamental design of the suspension is almost entirely different.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
  1. 1995 325 Ci compatability with 1999 M3 parts
    By Wjmaroni in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-16-2015, 08:44 AM
  2. 1995 325 Ci compatability with 1999 M3 parts
    By Wjmaroni in forum Forum Software Questions & Suggestions
    Last Post: 01-15-2015, 01:39 PM
  3. E36 with E90 M3 fitment wheels.
    By stupenduzzman in forum BMW Rides & Events
    Last Post: 05-30-2012, 12:36 PM
  4. E36 e36 M3 FCABs with OEM M3 bushings.
    By JimC3 in forum Suspensions, Springs & Shocks
    Last Post: 11-13-2011, 10:30 PM
  5. 1995 e36 M3 Help with Rims and Parts
    By EndlessM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-10-2009, 12:24 PM
