So I bought the 2000 323ci a month and half ago with a misfire (cylinder 1 and 5). heres what ive done and has not fixed the problem
- spark plugs
- tested ignition coils and fuel injectors
- tested the plug connecters and changed ignition wiring harness
- new oil filter and oil changed
- fuel filter and pump
- compression test all cylinders came back at 150-152
-changed disa valve
-intake and valve and valve cover gaskets are new
-vanos were swapped and new seals.
guy said the maf was new and camshaft sensors .
only other info I could give is sometimes the orange oil warning light comes on.
out of ideas!!!! any ideas would be helpful(:
Service Engine Light on? DTC Codes?
