Originally Posted by
jaredlourdon
Help! I bought some nice rims and tires off of craigslist, 235/45/17 for my 03 z4, I put them on today and the front tire is rubbing when the wheel is turned just alittle and i hit a bump. I live on a really bumpy road so its noticeable quite often, smooth roads its okay. The rub is coming from where the front bumper meets the side panel (that separation beside the headlight) it is just barely catching the plastic there but i worry if a hit a big bump if it would be strong enough to take the bumper off completely. Long story short, I'm looking for a solution, any product to raise the front suspension a tiny bit or maybe something to get the wheel from poking out that far. Like I say its barely scraping but something needs to change. Please help
Sounds like you have the wrong offset on the rims
The tire is not overly tall or wide and should work with stock suspension.
You don't to raise the ride height and honestly I do not know how you would
post some pics so we can see your issue.
BTW you will not rip the bumper off, it is secured top and bottom with bolts and screws.
04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
