The Turner Build Your Own Catch Can Kit
Catch Cans are an important and beneficial modification that can be utilized by nearly every vehicle. They provide valuable oil separation and can help extend the life of your engine as a result. Modern day emissions regulations require the use of a closed crankcase ventilation (PCV) system to recirculate combustion blow-by gases from the crankcase back in to the intake to be burned. Unfortunately, these blow by gases contain water vapor (which is a byproduct of combustion) and pick up oil mist from the windage cloud and cam lubrication system as they travel through the crank case. Due to less than 100% effective air/oil separation in the stock PCV system, some oil mist and water vapor mix and are carried back to the intake tract. Over time, the mixing can cause oil deposits and carbon buildup in the intake manifold, intake ports, and on the back of intake valves. All will eventually lead to poor performance and reduced fuel economy, and the presence oil mist can in the intake charge even increase the risk of engine damaging detonation.
The catch can utilizes a strategically designed 4 chamber baffle plate system engineered to create multiple changes in the direction of airflow to cause oil droplets to fall out of suspension, maximizing the efficiency of the PCV air/oil separation. A dipstick is integrated into the cap so you can monitor the oil level, and the can is easily serviced. At each oil change simply unscrew the canister and empty the trapped oil with your regular used oil. The Turner Motorsport Oil Catch Can is CNC machined from billet 6061-T6 aluminum and features a stealthy black anodized finish for lasting durability and appearance. The Turner Catch Can includes everything needed for an OEM-like and fully reversible installation. Another benefit offered by the Turner Catch Can is the ability to add on a drain kit so you no longer need to fumble around getting the fill can out of a tight space. The drain can be run down to the belly pan of your car so draining can be done at the same time you change your oil or anytime in between.
Click HERE for the Turner Build Your Own Catch Can Kit for your BMW
