Results 1 to 4 of 4
Thread: Vortech SC V3 shaft seal part number
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Dear all. Can you help me to identify part number of attached seal bearing for SC v3 vortech
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Dear All,
    Have a problems with oil out from SC. Is this seal the reason? I tried to find out more about it in one of my previous threads but had not clear info.
    Apr 2012
    Tampa, FL
    E36,E38, and E46
    I cant identify it however it looks like a conventional industrial seal. Measure inside and outside diameter in mm an find one with oil resistant material. The only other things I remember is that some industrial seal are rotational and some are linear for like a rod to extend out of. i beleive the linear style have extra ridges inside the outer wipers to hold pressure like motorcycle fork seals.
    The part numbers are similar to bearings. I.e. 3508. 35mm od and 8 mm id.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    You won’t find any number other than the Vortech specific part number... it means nothing outside of Vortech. The only guy to get the identical mechanical seal is Superchargerrebuilds.com The mechanical seal he sells is identical to the original. Do not try another type.
  1. Los Angeles Need ASAP Gear box Shaft Seal Part for Sunday
    By sofiabghome in forum 1992 - 1999 M3 (E36)
    Last Post: 01-06-2013, 12:46 PM
  2. Help Looking For Transsmission Seal Part Numbers??
    By uses0ap in forum 1995 - 2001 (E38)
    Last Post: 06-02-2012, 05:14 AM
  3. sunroof seal part number
    By Maximum55 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-16-2012, 09:05 AM
  4. Trunk Seal Part Number!!! Help ASAP (It's Raining)
    By 456meyer in forum 1991 - 1999 (E36)
    Last Post: 03-27-2008, 11:36 PM
  5. door seal part number ? Pics!
    By ArmySweitzer in forum 1996 - 2003 (E39)
    Last Post: 10-06-2007, 12:37 AM
