Results 1 to 2 of 2
Thread: Much needed BMW M3/M4 Jb4 Install DIY + Review
    Jan 2017
    Las Vegas
    Talking Much needed BMW M3/M4 Jb4 Install DIY + Review
    Description and video copied from BMW DIY Guy
    Check out his youtube channel
    https://www.youtube.com/channel/UC7z...KOhrg2il6nYpRg
    This is the full installation video for the Burger Tuning JB4 module, including the bluetooth adaptor and ODBC cable run.
    Thank you again to the excellent customer service from Mike of Extreme Power House, and his fantastic company!
    Product link:
    https://www.x-ph.com/burger-tuning-b...3-m4-f8x-tune/
    The installation is into a 2016 BMW M4 F83 with the automatic transmission, which makes it a little easier than a manual. NOTE: If you DO have a manual transmission, watch the guide I posted for the F32 JB4 installation, which will show you how to properly route the OBD cable through the firewall.
    The installation is really straight forward if you work carefully and take your time. Let me stress again here as I did in the video: ALWAYS disconnect your battery before doing this work! DO NOT have the battery connected, as you can damage your ECU, JB4 or both!
    I will also show how to attach the bluetooth module to the JB4 box so that is setup properly. I cannot recommend more highly getting the BT module and mobile app. While it isn't cheap, it gives you an amazing range of tools to work with your car, not just the benefit of reading codes and resets. Absolutely worth it.
    I also recommend running on map 1 to start, until you have a greater sense of what the maps mean for your setup and have read the information on those settings thoroughly. The maps 2 and above are for different modifications, fuel combinations and a number of other things. Refer to the n54tech dot com forums for information and configuration advice.
    Required parts and tools:
    JB4 with bluetooth module
    10mm socket
    13mm socket
    small pick tool or flat bladed screwdriver
    electrical tape or heat shrink
    Torx bit set and driver
    JB 4 Mobile android or iPhone app installed (HIGHLY recommended)
    Feb 2001
    Fort Lauderdale, FL.
    2020 X3M Competition
    Awesome!
    Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
  1. 2015 BMW M3 / M4 Dissected: Everything You Need to Know
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-28-2014, 09:45 AM
  2. How much? 1997 BMW M3 should I ask for?
    By Eli at Pelican in forum 1992 - 1999 M3 (E36)
    Last Post: 02-03-2006, 10:14 AM
  3. need e36 m3 nitrous kit install
    By 95M3VA in forum Forced Induction
    Last Post: 03-26-2005, 05:53 PM
  4. how much does bmw charge for clutch install?
    By Cosmos96 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-10-2004, 11:39 AM
  5. BMW ///M3 ""stealth"" Fiberglass install
    By ClubSport332ti in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-18-2004, 11:41 AM
