Results 1 to 5 of 5
Thread: Another headliner removal..
    Sep 2017
    Pittsburgh PA
    1989 BMW 325is
    The sunroof needs readjusted... it won't even budge. I have searched and attempted to remove the headliner to get to the cassette. However... I can't find a thread that applies to me. Is it possible to remove the headliner on an e30 if the sunroof is stuck completely closed? I removed everything attached but I cannot get to the screws holding this piece in
    Any advice? Thanks in advance
    Sep 2017
    Pittsburgh PA
    1989 BMW 325is
    Sunroof won't budge, headliner removal?
    Hey all. Just bought my first e30. The sunroof is stuck shut but needs adjusted... its open in one corner allowing water in. I cannot move the sunroof at all to remove the headliner. Is it possible to do this? Thank you!
    Regina, Sask, Canada
    82 320i 89 325i
    arrgh sunroofs. you actually have to move them to work on them even when broken. it can be a two-person job to force them back in order to access the clips to remove the headliner, but it is really the only way. trouble is you may cause further damage achieving it.
    you might find this helpful : http://e30.bmwdiy.info/sunroof-adjust/
    good luck
    Oct 2017
    Lutherville, Maryland USA
    1986 325es coupe
    How do you replace the sunroof seal. All working but small leak. Dan
    82 320i 89 325i
    follow the diy posted. the difference is you will remove the 6 torx bolts completely instead of loosening them, then lift the sunroof out entirely. once out mark the point(s) where the sunroof gasket meets itself. peel off old gasket, install new gasket, install sunroof. e30 sunroof seals come as either a single or a two part. you might be able to install the two part version with the sunroof still on the car. i have never done it that way.
    sunroofs are easier once you've worked on a few. they are easier to understand once you've seen them apart. i took one apart at a wrecker the first time before working on my car to get a better idea. i strongly recommend doing this before tearing into your own.
  1. Headliner removal - E36 Sedan
    By Doug001 in forum 1991 - 1999 (E36)
    Last Post: 11-23-2016, 10:44 PM
  2. DIY headliner removal?
    By urs1ne in forum 1991 - 1999 (E36)
    Last Post: 06-21-2006, 07:18 AM
  3. Headliner Removal
    By lachssilberbim in forum 1983 - 1991 (E30)
    Last Post: 06-27-2005, 11:55 AM
  4. headliner removal
    By Bernanke in forum 1983 - 1991 (E30)
    Last Post: 01-07-2003, 07:50 PM
  5. Headliner removal procedure?
    By NormK in forum 1992 - 1999 M3 (E36)
    Last Post: 08-19-2001, 10:52 PM
