Results 1 to 25 of 41
Thread: E36 transmission options
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    Hello again, I am wondering what transmission would be suitable for a turbo charged e36. I have destroyed 2 manual transmission in my 1992 325i (sounds like a fist full of gravel was thrown inside).
    About my car:
    1992 325i
    M50 engine
    Bore:86mm
    Stroke:91mm
    Turbonetics turbo t3/t40e
    Is there an option for an automatic transmission? If so is there clutch kits to hold more power for it?
    Another manual transmission option?
    What are you currently running? Any help would be appreciated thank in advance.
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Zf320 from the e36 m3/328 or a 420g from the e46 m3 or euro e36 m3
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    Will I be needing a different drive shaft for this?
    Apr 2006
    Minnesota eh?
    86 325es
    If you are interested in an automatic I am making adapter plates to use a GM auto. I had one made one for myself a few months ago and I had 10 more made to sell. Any GM auto will work, powerglide, th200r4, th350, th400, 700r4, 4l60e, 4l80e,
    This was also a member that was making adapters for a ford C4 but I think he stopped making them.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The OP's Getrag 250 is not as strong as the ZF320. Easiest to change to the ZF320. The Getrag 420G is expensive and gets mixed reviews. The ZF 6 speed is also expensive. And an auto conversion will be expensive though it is probably the best choice if the primary goal is to go quick on the dragstrip. I am leaning toward the T56 Magnum, which will be a $4k swap plus I will need a different clutch and a modified driveshaft.
    Sep 2008
    Toronto, ON
    6465 328ti
    I will say, if going 420g DO NOT use the euro 6speed. The input shaft is quite smaller than its e46 counterpart and breaks easily. I snapped one and so has chikinhed I believe. Running an e46 420g now and I think it will be up to the task, for awhile. If not T56 magnum time
    Apr 2006
    Minnesota eh?
    86 325es
    Don't necessarily need a new clutch for the T56. Just need to change the hubs on the clutch discs to 26 spline. Clutch net did this for me when I ordered my first clutch from them for free.
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    If I changed to a ZF320 do I need a different driveshaft at all? The reason for the automatic thought is my knee does not like the clutch anymore. I can give another manual trans a shot as long as it will hold up.
    Jun 2005
    New England
    You need a different front half of the DS and guibo and shift linkage.
    My next car will be DCT or similar or auto. Today, autos outperform manuals. 10 or 20 years ago or more, manuals outperformed autos.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    You'll be back to a manual after that. Trust me. Once you have a glass DCT that can't hold any power and is stupid $$$ to repair. I had an auto 335 and it was awful. Engine was wonderful if you could ever control it (ie couldn't, stupid auto).
    Jun 2005
    New England
    I am thinking 991.1TT PDK.
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    So I just want to confirm these are the only BMW manual trans option available?
    320g is better then what I currently have? What kind of power can that one hold? What years and models does this come from? What do I need to swap to this trans?
    420g expensive? What kind of power can’t it hold? What years and models does this come from? What do I need to swap to this trans?
    Hagerstown, Md
    1995 M3 Drag C4 Auto
    What type of driving do you do? Do you drag race or street race? Do you plan on making more power at some point? Are you sick of breaking parts?
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    I would like to try and take it to a track some day, mainly just drag race and drive to work a couple times a year.
    Possibly a little more power at some point. Right now I can not even get it fully tuned due to transmissions blow up every time I hit the gas pedal.
    Very sick of breaking the transmissions
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    The idea behind this car was too keep it as sleeper as possible. The only things that are not stock looking when you look at it are:
    Wheels
    Seats
    Seat belts
    At this point I’m getting tired of breaking the transmission. And may be willing to change the shifter area of the car a little. I may be able to design a shifter that will work with a TH400 and still look oem inside the car
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    May 2003
    Richmond, Virginia
    Lots.
    Despite shifting stupid fast and being very quick, I'd recommend against a PDK 991. Just FYI.
    915whp '98 M3 Sedan /// 37k Mile '95 M3
    Jun 2005
    New England
    Quote Originally Posted by 95RogueM3 View Post
    Then I can’t buy a 991.1TT, because the 991TT comes only with PDK. It’s a very good trans. Way better than the old one in the 997.1TT.
    Autos and Dual clutch like pdk or dct work great with forced induction. Pretty much no drop in boost when shifting and they shift faster than a human.
    May 2003
    Richmond, Virginia
    Lots.
    If you like DCT, then you will love PDK. I was speaking more about the 991 TT (and really most of the high performance cars that only come in dual clutch) that they truly are lacking the fun associated with rowing gears-- except for those occasions when you are all-out or on track. I've driven a 991TT extensively and its super fast, and the gear changes are near instant (and the machine gun burble on downshifts makes me chuckle), but I would still pick a manual option. I am currently shopping something more exotic and while I love the idea of an MP4-12C, am worried about the lack of involvement.
    Yes, tiptronic on the 997.1 was terrible. No comparison to PDK.
    Vancouver, BC Ca
    1993 325is
    An acquaintance of mine (fellow autocrosser) and regular OLOA participant has had a nightmarish time with his MP4-12C. Nothing but problems with the engine mgmt and turbos.
    He was so pissed about Woking not getting the car sorted in time last year that he went out the week before One Lap and bought this instead:
    May 2003
    Richmond, Virginia
    Lots.
    Quote Originally Posted by jakermac View Post
    The more I read about them, the more its apparent they shouldn't be owned outside of warranty. On a positive, McLaren allows you to extend warranty out to 10 years after production, however at a cost of ~$4,500/year. Seems like most people suffer with electronic issues moreso than drivetrain -- though I have seen transmission replacements, etc. While evidently crazy fast, again, just not sure for my weekend and pleasure use I'd really enjoy an "automatic" transmission. The PDK confirmed that for me, which rules out DCT M Cars, PDK cars, and older technology like E-Gear and SMG as just not quite involved enough, despite technically being faster/better than I am.
    Back to the thread...the T56 while expensive is a pretty awesome feel. I don't have a shorter throw on mine, and yet it still feels like you are operating a bolt action rifle. Definitely better than any BMW box I've felt...
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    So if I wanted to do the ZF trans as a bandaid until I have time to get something else fitted what parts would I need to put it in. Is the driveshaft front the same between the getrag 250 and the ZF320? Shifter linkage?
    Jun 2005
    New England
    Front half of DS is different, guibo is different, linkage is different.
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    So I would be looking for
    the shift linkage
    Driveshaft
    guibo
    My car is a 1992 325i 4 door will there be a driveshaft that will fit without modifications?
    Jun 2005
    New England
    Is it 4 bolt or 6 bolt at the diff? The DS for ZF320 cars may be 6 bolt for early models like 95M3 or 96 328/M3 but most later cars seem to have a 4 bolt rear. The rear of your current DS will fit the front of a ZF320 DS. The trans output fkangevis bigger diameter so you need the bigger guibo and bigger front half of the DS. The linkage differs because the shifter console has a different shaped hole at the trans end. I forget whether the shift selector rod differs. I did only one conversion and it was years ago.
  1. S65 V8 6 speed transmission options for e36 swap
    By Kart Racer in forum Engine Conversions
    Last Post: 12-30-2019, 08:04 PM
  2. E36 FS - [E36 Transmission Brace w/ UUC Red Mounts + Enforcer Cups] - $50 SHIPPED
    By fritzintn in forum Drivetrain & Transmission Parts
    Last Post: 07-24-2012, 03:34 PM
  3. E36 WTB:E36:transmission
    By wishingtree in forum BMW Parts Wanted
    Last Post: 04-15-2012, 06:37 PM
  4. E36 1998 m3 e36 transmission
    By Alex325is in forum Drivetrain & Transmission Parts
    Last Post: 11-03-2010, 06:27 PM
  5. E36 Wtb: E36 Transmission Crossmember
    By aaronsm3 in forum BMW Parts Wanted
    Last Post: 03-11-2010, 03:10 PM
