My 1987 BMW was running perfectly, now it does not even start. The spark plugs are not sparking. Can someone tell me what the issue is? If I changed the rotor and wires as well as the spark plugs, what would the next step be? I do not want to throw money on parts I want to get straight to the problem.
Well for instance if the carbon pin in the cap is gone that would be a problem. So you need to check the basics, the e30's had a some power wires to the fuse box from the battery cables. You need to find out where you are losing the 12 volts
do you have fuel ? do you have power to the coil ? what tests have done re: bentley ? is it an i or an e and have you tested the sensors ?
With an i, no reference signal will result in no spark and no power to the fuel pump. so you need to test the resistance of the crank sensor, and also with an oscilloscope if available. I had this issue with my 92 shortly before somebody hit me in the quarter with a 2005 Silverado. Which is the main reason I now own a 2000 740i sport.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
an e or I model? the ignition pick up is in different spots between the models.
No e30s again.
is it a 325i, 318i, or 325e? all three have different motors
No e30s again.
Use the Bentley. Check coil voltage (with battery fully charged), check coil resistance. Did you also replace the rotor or just the distributor cap? Are you sure you have the wires in the correct position on the cap? Have you checked the resistance of crank position sensor? Problems with any of these or the computer will cause a no spark for the 325i engine. Lack of fuel will not effect no spark, but it will effect a no start :-)
Cheers,
Joe
I have 3 e30s. One had a rusty body with a good engine. I took the engine and put it in the good chassis. After the conversion, that's when the issues occurred.
swap in the ecu from the donor.
edit: also pull and test the cps. or swap both sensors over from the original donor with the ecu
yup /\
No e30s again.
did you plug in the green box above, or right next to the ecu? there is also a single plug wire that needs to be plugged in right around that area, too
No e30s again.
dme ? one sensor? both ?
what values did you get testing the cps ?
what dme are you running ? 173, 153, 154, 525, 027 ? . is the swapped one the same as the original ?
most e models up here run a 154 or 027, depending on if it is motronic 1.0, 1.1, or 1.3. there are compatibility issues between them. 87 is a crap year for them as it can be any which makes finding the right one a pain.
will your car run a stomp test ?
dunno if it helps but every e no spark situation i've seen up here has been a fried dme, bad cps, or poor coil. always got them moving in the end tho. hope you can get to the bottom of it.
Dang. Where do you have it for sale? South texas ?
