Results 1 to 5 of 5
Thread: 2006 e61 folding mirrors.
    Nov 2013
    Latvia
    e39 530d 00`
    Hello everyone! I got a problem,bought a car about month ago. Noticed,that i cant adjust drivesr side mirror and cant fold them,with folding button. I stripped the door,and found out that the drivers side mirror connector wasnt plugged in. So i did,and now i can regulate both mirrors. But still,folding is not working. When i press fold button,no clicking sound,absoulutley nothing,silent. Maybe there is some kind of reset procedure,because there was error and drivers mirror wasnt connected to eletricity?
    fuse in glow box is fine.
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    May well be your e61 doesn't have the folding mirror option, even if you have the button. Have you decoded your VIN number to look at the vehicle build order?
    https://www.bmwvin.com/
    Nov 2013
    Latvia
    e39 530d 00`
    I checked, I have working folding button,and when i put the juice to the mirrors,they both fold with no problems. So the mirrors basicly are working and the button in door are working as well. Maybe there is some coding problem?
    Feb 2010
    Atlantic Beach, Fl
    It would appear the folding mirror option just has not been activated, with any luck. Take a look at the app, Carly for BMW, at your App Store and their OBD connector. The Carly app has the ability to activate the folding mirror option, where installed.
    http://www.mycarly.com/product/bmw-app/
    Aug 2016
    Next to Snowden
    Not a BMW that's for sur
    With older cars, the contacts in the switches can wear out. Disassemble the door, unplug the switch, using a wiring diagram (Bentley?) to identify the leads, and see if jumping the leads will trigger the mirrors. If yes, then the panel switch is bad. If you can dissaessembe the switch, do so and clean with contact cleaner. Else replace the switch.
  1. E60,E61 FS: E60 E61 Powered Mirrors with LED & Folding Function
    By Stills in forum Exterior Lighting & Body Parts
    Last Post: 10-22-2015, 03:50 AM
  2. E61,2006 530xi power-fold mirrors ?
    By E61530xiwagon in forum 2004-2010 (E60,E61)
    Last Post: 02-16-2010, 12:25 AM
  3. Has anyone upgraded to electric power folding mirrors?
    By humanite in forum 1995 - 2001 (E38)
    Last Post: 03-23-2004, 11:28 PM
  4. Folding Mirrors Standard?????
    By DaveLSB///M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 05-18-2003, 05:59 PM
  5. Gauging interest (folding mirror related)
    By RichP in forum 1999 - 2006 (E46)
    Last Post: 10-21-2002, 10:12 PM
