RM European Auto Parts
Results 1 to 13 of 13
Thread: Drivetrain malfunction reduce power 2013 BMW 328i
    Sep 2017
    Tamps Fl
    2013 BMW 328i
    Please help. My car is out of warranty and Im trying to figure out why its stuck on limp mode. At first it started doing this at statrup on occassions, but slowly it has gotten worse to the point of it always being on limp mode. I have already changed all spark plugs as well as all the coils. Yesterday i had my car professionally scanned and this is the codes that it gave me:
    123401 electric wastegate, learning stop: malfunction during catalyc converter heating
    123432 electric wastegate, learning stop: stop position (wastegate closed) outside valid range
    120408 chargin pressure control, deactivation: pressure build-up blocked
    Any help will be appreciated. Thank you!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    It would seem that your wastegate isn't closing. I'd suggest that you replace the vacuum hoses; They live in a difficult environment. You might also want to use a hand-operated vacuum pump to make sure that delivering vacuum causes the wastegate control rod to move.
    Chris Powell
    BMWCCA 274412
    He's got an electric wastegate actuator. Time to replace it.
    Sep 2017
    Tamps Fl
    2013 BMW 328i
    Thank you for the reply. Am i able to change the wastegate actuator without having to replace the entire turbo?
    Yes, it's a separate part. But, it will need to be adjusted and tested properly using genuine BMW software. You can't just bolt it up and clear the fault. Well, you could, but it's a slim chance you get the length of the rod exactly right.
    Sep 2017
    Tamps Fl
    2013 BMW 328i
    And do you beleive this will fix my drivetrain malfunction limp kode issue? I honestly dont want to take it into the dealers since i had bad experiences with them
    Jun 2002
    E39M5, E500 4WD
    Thank you for catching my error, White94RX !
    Ramos, please note that White94RX is a Level 1 BMW dealer master tech....officially, he's my competition. But while I certainly would have found out, quickly, that your car had an electronic wastegate -- HE already knew that. And, while I have ISTA (BMW's computer) at my shop, White94RX already knew that ISTA needs to be used to adjust the wastegate linkage.
    What I'm saying is that the dealership still has the best information and experience, for dealing with your young and complex car. You can instead decide to enlist the services of a top quality, extremely well equipped indie BMW specialist, if you feel so strongly. But seriously, you cannot possibly deal with your car without using extremely specialized BMW software.
    Chris Powell
    BMWCCA 274412
    Thanks for the kind words!
    Sep 2017
    Tamps Fl
    2013 BMW 328i
    I really appreciate your reply. I honestly just want to get the car fix. I drive an hour to work everyday in order to provide for my family and im trying to get the car fix so it doesnt break down on me on my way to work. I preffer any solution that doesnt involve dealership, only because i had so many bad experiences where the dealers tell me parts are wrong with the car that are not and i end up spending thousands of dollars on things that the car truthfully didnt really need. Please help me!
    Jun 2002
    E39M5, E500 4WD
    Um, you've been told what's broken, what part you need to replace, and the computer that needs to be used to calibrate the new part. I don't see any way we can be of more help than that??
    Oh, the ISTA software will also have a guided test plan for your codes. White 94 RX has maybe seen enough of this failure to not need to follow that test plan. I would personally follow the test regime, to provide documentation as to why I was calling for the part. But of course, that testing equals more labor charge.
    Chris Powell
    BMWCCA 274412
    May 2009
    Fullerton, CA
    325i
    Curious, what ended up happening, Ramos? My car is doing the exact same thing. Curious if you took it to the dealer and they were able to fix it as well as the approximate cost.
    Feb 2019
    Irvine, CA
    2013 BMW X1
    CourtneyDC/Ramos - my 2013 X1 has the same problem. Did you fix your car issue? was it with dealer or indy shop? My dealer is asking to change the Guibo (flex disc) as the rear is starting to crack and ELECTRIC WASTEGATE FAULT, DME SOFTWARE ERROR PER TEST, PROGRAM (UPDATE AND RECHECK). I replaced a new battery and next day I got into a limp mode. Dealer claims that, the old battery did not read all the sensors and now with new one, it is recognizing the problem. He quoted around $1000 to get this fixed. Please advice!.
    Regards,
    Brad
    my 1st BMW.
    May 2012
    Oregon
    2010 328I M3
    Also have this issue on a s55
    123432 - Electric Wastegate, learning limit stop - Stop position (wastegate close) outside tolerance
    I have ista but need more instructions on how to do it didnt find this under service functions.
    Thanks in Advance
    Thanks in Advance
  1. New 535xi - Engine Malfunction Reduced Power
    By bishbmw in forum 2004-2010 (E60,E61)
    Last Post: 03-24-2012, 07:29 PM
  2. Engine Malfunction / Reduced Power Available
    By drgonzal in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-01-2009, 11:01 AM
  3. 2008 535xi "Engine malfunction! Reduced power" warning
    By JoDoSt in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-31-2009, 02:13 PM
  4. Engine Malfunction/Reducing Power
    By Flanker in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-24-2008, 08:49 PM
  5. 745i 2002 - Engine Malfunction - reduced power
    By hans745i in forum 1995 - 2001 (E38)
    Last Post: 12-04-2006, 07:37 PM
