Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: Tire size
    Oct 2016
    Oklahkma City, OK
    1993 BMW 325is
    Tire size
    I'm looking into some wheels, I'm pretty sure they will work but can anyone confirm? They will be on the rear of a 1993 E36 325IS
    Wheel: 17×9.5 with a 20 offset
    Tire: 275/40R17
    Sent from my SM-G955U using Tapatalk
    Aug 2013
    1999 BMW M3 Coupe
    That's awfully wide for an E36, and with a low offset. On my E36 M3 which should have basically the same wheel well dimensions, I run a 17x9 ET42 with a 245/40-17 in the rear. I could run a 255/40-17 on that with some fender rolling. Anything wider than 255 and I'd have to cut the fenders or put a wide body kit on.
    Your wheels are 22mm lower offset, so they stick out that much closer to the fenders. I doubt anything wider than a 225/45-17 would fit on that wheel due to the decreased clearance to the fender. And a 225 on a 9.5 inch wheel will be very stretched.
    On E36's generally you want very high offset wheels in back because there's hardly any fender flare to fit very wide tires. High offset also works in front with small spacers, or you can run lower offset in front with no spacers.
    California BAY AREA
    e30 M3, 335d
    Unfortunately those wheels will be far too wide to fit a stock-body E36. If you're running fender flares or some type of widebody, they'll fit great. Otherwise, you'll want to stick to an offset in the ≈40mm range for a 9.5" wide wheel, and even then, you'll still need to roll the rear fenders. Check out our E36 fitment thread to get an idea of how far the limits can be pushed in terms of wiiiide E36 fitments: https://www.bimmerforums.com/forum/s...-Fitment-Guide
  1. What tire size should I order?....more
    By bmwmsport in forum 1991 - 1999 (E36)
    Last Post: 08-03-2020, 03:43 PM
  2. Tire size recommendations for 18x8.5 on 95 M3
    By DrewsM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-16-2001, 04:18 AM
  3. Increasing 17inch tire sizes
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2001, 05:32 AM
  4. Would rim&tire size effect Dyno numbers?
    By BMBrad in forum 1992 - 1999 M3 (E36)
    Last Post: 05-11-2001, 08:39 PM
  5. Tire Sizes
    By Mike325i in forum 1991 - 1999 (E36)
    Last Post: 04-07-2001, 07:01 PM
