Results 1 to 25 of 35
Thread: Chipster Siemens-MS41-Flash-Tool site down
    Jul 2015
    Ohio
    1992 525i, 1999 528iT
    I can't seem to find my copy of Siemens-MS41-Flash-Tool on my back up hard drive and the site is down. I think I heard the creator died and his family took down the server.
    Does anybody have a copy of the software they can send me?
    Sep 2017
    USA
    2x E36, 240sx, lancer
    If someone could do this i would also need a copy i cant find any other program to flash my ecu with
    Jul 2004
    Houston, TX
    36 Cylinders
    Galletto 1260 program with a basic KKL or K+DCAN cable will flash it fine.
    You'd have to correct checksums with something else.
    MPPS v13 clone interface works well on MS41. Super cheap too.
    Free checksum correction: http://www.bmweditor.com/Home/Check
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2017
    USA
    i tried the galletto 1260 already but it kept telling me connection impossible or something like that
    havent tried mpps v13 tho was really hoping to get ahold of somebody i could get chipsters one because i heard its good
    Jul 2015
    Ohio
    Quote Originally Posted by Dive236 View Post
    Yeah I've had zero luck with galletto
    Sent from my SM-G955U using Tapatalk
    Jul 2004
    Houston, TX
    36 Cylinders
    You need to use MProg program to read your USB cable's serial number (Read and Parse), then use a hex editor on the “EOBD1260.exe” file browse to offset 0x249E90 or search for text string “marca”.
    There is an 8 character serial number written after 'marca', something like A8UDVPWH...
    Get your cable's serial number and type it instead of that serial. Save file and it will work.
    -Abel
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Abel, I hear (read) talk that some of the RomRaider guys are working on supplying the MS41 Flash Tool again. Do you know anything about it yet?
    Jul 2004
    Houston, TX
    36 Cylinders
    Kim's passing hit us all by surprise.
    I know there was initial talk about doing something with his work in a best manner to benefit his family or his memory. It's still being figured out.
    Until then, it's not fair to release all his genius hard work from an alternate source besides the original hard working developers of the MS41 definitions. I hope others can see it this way too.
    -Abel
    DeWitt, Michigan
    Sep 2017
    London
    Bmw
    I have a copy which i am
    Not sure if it is against rules here to pass on
    Initially i used gellato cable, bridged pin 14 and 18 , used romraider and changed rpm to 7k
    If not againt rules, i can post a download link here
    Jul 2015
    Ohio
    Quote Originally Posted by Drifter17a View Post
    Do you mind sending me a link via pm?
    Sep 2017
    London
    Bmw
    Quote Originally Posted by cgott91 View Post
    Done
    Apr 2016
    Colorado
    98 328i 4 door coupe
    if you dont mind may you send that link my way as well ive been looking for it forever now?
    Sep 2017
    Alberta, Canada
    2006 BMW 325XI 3.0litre
    Hey Drifter,
    Could you PM me that link aswell? I havent had any luck using a different program/tool.
    Much appreciated!
    Mar 2003
    Toronto, CANADA
    74 tii, 93 M5 x2
    What are you needing Kim's flasher for? I have ways to flash your ECU over the internet, if you have a D-CAN cable and I assume that you do.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    are you offering this service to members for free is the question?
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Dec 2009
    CA,
    95 M3
    Would any one have Chipsters Siemens_MS41_binary_tool https://www.youtube.com/watch?v=ZDxzT0K1LuE
    DeWitt, Michigan
    The software in that video is pretty interesting. I haven't seen that one before.. Maybe 328 Power 04 knows something about it?
    Jul 2004
    Houston, TX
    36 Cylinders
    I don't have it; didn't have a real need since you can get all that info out of the hexdump with a simple hex editor.
    -Abel
    DeWitt, Michigan
    Yeah, I just took a better look at the video. It doesn't really seem to do anything super great, but I guess if all you wanted to do was raise your rev limiter it would be handy... We're not all hex ninjas like you!
    Dec 2009
    CA,
    95 M3
    All I wanted it for just to see what is that Rev limiter set it on the File
    Mar 2012
    Renton, Wa
    98 m3
    Dont we think sharing a paid for software of a deceased guy is a little wrong..?
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    DeWitt, Michigan
    Quote Originally Posted by vollosso View Post
    That was my initial inclination too. I happily paid the very reasonable price for Kim's excellent software when he was alive, and if his family wanted to keep his website going I would happily continue to pay them for what I needed from there. His family should be able to continue to profit from his work if they want to.
    HOWEVER, they don't want to continue selling his software. At that point I see no problem with sharing his software and continuing to appreciate his contribution to the community. No one is being harmed, and his legacy lives on. It's what I would want if I were him. But I'm old, and might have pondered morose things like this more than you young guys. Lol
    Mar 2012
    Renton, Wa
    98 m3
    Well maybe its because knew kim and what went down... regardless his friends are working to get everything back running.. time will tell..
    1989 535i - sold
    DeWitt, Michigan
    I have suggested to one guy that he goes with the new MS41 flasher busterhax just released, but it's because that seems likely to be supported into the future. But a far as some of Kim's other software like this thread was about, it seems unlikely that anyone else is going to recreate it.
  1. Are the johnvpower.net and Johnvkademics sites down???
    By Jed in forum Middle Atlantic - US
    Last Post: 02-14-2019, 11:10 AM
  2. Siemens MS41.x chip types/models
    By NickG in forum Forced Induction
    Last Post: 09-21-2009, 06:11 AM
  3. Siemens MS41.1 Hacking
    By LinearX in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2008, 09:17 PM
  4. Is Tricord's site down?
    By Echo in forum 1975 - 1983 (E21)
    Last Post: 01-21-2005, 01:48 PM
  5. Why is this site down again?
    By outkastaliens in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-19-2001, 02:12 PM
