Results 1 to 7 of 7
Thread: Tiny ADS Interface inside 20 pin connector/software question
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    Question Tiny ADS Interface inside 20 pin connector/software question
    Hello,
    I bought one of these http://openlabs.co/store/Tiny-ADS-In...-pin-connector with the understanding that it would work to scan my 1995 E36 325is since I needed a cable that can read the L-line (pin 15) on the 20pin connector under my hood.
    Ive tried using it with the "Mike's Easy BMW Tools Package" and it just wont work. I went in and changed the interface to ADS but still nothing.
    I have the PA Soft 1.4 software and that tool but it only reads a few things. I thought getting this new connector from openlabs would allow me to read the DME and transmission computer plus a whole lot of other things.
    Any idea as to what I should do? Has anyone bought the connector I linked above and has had success with older non-OBDII bmws?
    As always, thank you all for the input.
    Jul 2004
    Houston, TX
    36 Cylinders
    Not sure how Mikes package is set up, but it sounds like a newer pack... TinyADS only works with the older EDIABAS (v6.4.3 or 6.4.7) on 32-bit windows (x86), and on a true serial port.
    Also, Dell laptops need a special ADS driver.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    I have a old dell with a serial port. What kind of ADS driver is needed and how do I go about getting said ADS driver?
    Jul 2004
    Houston, TX
    36 Cylinders
    David MC posted it here. https://www.bimmerforums.com/forum/s...3#post29760473
    But that file gets replaced into ediabas 6.4.3 - 6.4.7 .
    7.0.0 - 7.3.0 will not work.
    -Abel
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    O man you are a time saver, I probably would have been troubleshooting and researching this issue for a lot longer than I will be now thanks to you.
    When I get home ill try to install the ediabas 6.4.7 version and get the ADS driver from that post.
    Thanks again
    Jul 2004
    Houston, TX
    36 Cylinders
    You can just copy the ediabas 6.7.3 files replacing your newer EDIABAS, instead of having to do a full install. The whole EDIABAS folder.
    -Abel
    Jun 2008
    Surf City, NC
    1995 Dakar M3
    Got the ADS connector working with EDIABAS 6.7.3, the only thing I cannot get to scan is the transmission computer. Any ideas as to why it wont connect to that?
  1. Replies: 60
    Last Post: 04-13-2017, 08:26 PM
  2. 20 pin connector
    By MC EUROS in forum Diagnostic Software
    Last Post: 12-10-2009, 11:29 PM
  3. Replies: 3
    Last Post: 11-25-2009, 12:05 PM
  4. Measured Voltage at 20 Pin Connector
    By Dreamer99 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-19-2008, 12:55 PM
  5. E26 20 pin connector
    By Profpatpending2 in forum 1991 - 1999 (E36)
    Last Post: 11-21-2006, 03:03 PM
