Results 1 to 10 of 10
Thread: tacometer
    Apr 2017
    denmark
    bmw e87 118d and e10 02
    tacometer
    Can anybody help with diagrams or just knowing what poles on taco i have to use, my taco is dead. Have a used one and befor i put it in the instrument, i want to check it, but i donīt know which is + and - and signal from ECU on the taco instrument.
    Help! Cheers Mike
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    The tach isn't quite so simple on the e30. Input to the tach is an output from the SI board. Dead tachs are usually SI board problems.
    "Howdy, Folks!"
    Valencia, CA
    Imola E36 M3 E30 Touring
    I wish my car had a tacometer, I could always use a good taco. Hope you get yours working, would hate for you to go hungry.
    Apr 2017
    denmark
    The problem is i need it for my 2002tii, so if anybody knows which pin on the taco is +,- or signal. Regards Mike
    Valencia, CA
    Quote Originally Posted by mikebike7 View Post
    It's a tachometer, please stop saying taco, it's too much for me!
    Second, there isn't a + or - pin, the tachometer is controlled by a microprocessor in the SI board, which gets its signaling from the engine DME. It's all digital, the closest you could get to a +/- would be I guess to look at the stepper motor pins directly on the tach, but good luck with that.
    Regina, Sask, Canada
    82 320i 89 325i
    you are in the wrong section. and yes your tach will have at least one wire direct from the distributor, maybe two, and maybe one from distributor and one from coil, all depending which ignition system is installed. it was common to switch ignition systems out on earlier cars. if you have an engine swap then good luck, it all depends on what set up was installed.
    Mar 2017
    San diego, California
    91 318is. 88 325 vert
    Its the SI board...Have the same problem. Replaced the Si Batts and nothing. Have to send it in to get the capasitors and transformers replaced.
    82 320i 89 325i
    there is no SI board on an 02
    Mar 2017
    My bad...missed the 02 part
    82 320i 89 325i
    we all did
  1. need help with wierd tacometer issue.
    By silvabmdub in forum 1991 - 1999 (E36)
    Last Post: 01-11-2012, 12:02 AM
  2. backlight is out for the tacometer, how do i replace?
    By alienwork in forum 1988 - 1996 (E34)
    Last Post: 09-27-2008, 02:19 AM
  3. New Tacometer gauge that shows redline is at 7000.
    By omak81 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-05-2007, 03:47 PM
